crazy idle prob.
Old Feb 26, 2007 | 11:30 AM
jdmlude5
Guest
Posts: n/a
Default crazy idle prob.
i have a 96 prelude si with jdm h22a, cai,apex ni exhaust, exedy stage 2 cluct 8.5 pd flywheel, v-afc, dc header, obd2 2 obd1 adapter,skunk 2 coil overs on koni adjustables. well my car is idleing like ****. it surges but not like an iac prob. a slow surge. and my plugs read lean no matter what i do with the fuel. now i had my head ported and polished about a year ago. had no prob out of it. i have replaced the iac map switched ecu injectors. some help would be great..
Old Feb 26, 2007 | 02:24 PM
preludeh22a1's Avatar
Default Re: crazy idle prob. (jdmlude5)
hi, everyone has that problem, i also have that problem, try looking on the vacuum lines, throttle body if its dirty juz clean it. i dont have a ported head, mine is mostly boltons, so it might be those stuffs. dont worry alot more people will help you here. later.
Old Feb 26, 2007 | 03:08 PM
91SI92's Avatar
hey whats up. had the same problem. if its idling like round 2 to 3000 rpm its the fast idle valve under the throttle body. 2 hoses run to. they say to take the 2 8mm screws off n turn it clockwise 1full turn then a half a turn. try that.
Old Feb 26, 2007 | 04:15 PM
jdmlude5
Guest
Posts: n/a
Default Re: crazy idle prob. (91SI92)
yeah i have had the throttle body off and cleaned it. and the fast idle valve i allready adjusted it cause my car was idleing real bad when it was cold. so i turned it in all the way. i even went to the junk yard and got a used throttlebody and still have the same prob.
Old Feb 26, 2007 | 04:27 PM
jdmlude5
Guest
Posts: n/a
also it aint that it idles to high its that it idles low. and i could turn the idle screw out real far and after a little driving it starts doin it again.
Old Feb 26, 2007 | 06:30 PM
that FITV is a pain in the ***, i got mine adjusted, it was running fine then after couple days it went back again and idle is too low, it would go to 500. im getting tired of this, ill juz buy a new one. period. is it expensive? i havent visited honda parts recently.
Old Feb 27, 2007 | 05:02 PM
i called honda parts today, they told me its 76 bucks but thats w/o tax, i forgot to ask if it includes like the little gaskets or o ring what you call. or the other way you could take it off and disassemble it and clean it with carb cleaner, thats what i read on some integra forums. i might try it this fri, disassemble and clean the hell out of it.
Old Feb 28, 2007 | 01:09 PM
jdmlude5
Guest
Posts: n/a
Default Re: crazy idle prob. (preludeh22a1)
that is the thing under the throttle body rite...
Old Feb 28, 2007 | 01:52 PM
yes correct. i called honda parts, but its goin to be special order. when i asked about parts i always say from a 96 prelude dohc vtec because i have a 92 with a 96 h22a1 and i dont want them to get confuse with f22.
oh i forgot they're goin to ask to if its manual or automatic, well mine is automatic, i dont know if theres a difference in price. but i think it will make difference if you clean it and adjust it, it might save some money too.
some say it gets loose because of vibrations in the car like when u have catback exhaust or a loud system.
Old Feb 28, 2007 | 03:37 PM
jdmlude5
Guest
Posts: n/a
cool get bc and let me no how it works out i gonna give it a shot also. mine is a 96. but it is now obd1 with jdm h22a. manual.
Old Feb 28, 2007 | 09:18 PM
91SI92's Avatar
hey whats up. i just fixed mine by changin the whole assembly. its like 3 10mm bolts that hold it to the throttle body underneath. b careful tho cuz coolant does run thru it. also make sure u bleed the coolant system when u get erything hooked back up or it will do it again, but jus a lil bit. let me kno how erything goes.
Old Feb 28, 2007 | 09:21 PM
91SI92's Avatar
also try sprayin starting fluid over your vacuum lines and where the intake man meet the head to see if u have any leaks. it'll suck in the fluid n act like it wants to cut off if u have a leak. so basically spray erywhere there is a gasket for the intake man.
Old Mar 1, 2007 | 08:25 AM
thanx. i got a noob question, well i guess i havent did it before, how do u bleed your coolant? is it juz draining your coolant from the radiator? if that it then it will be easy for me.
how did it cost you to replace the whole thing? did you buy the whole Fitv? does include the gaskets on it?
mine barely does it, but ill still check on it and clean it.
thanx dude.
Old Mar 1, 2007 | 10:12 AM
jdmlude5
Guest
Posts: n/a
were your lower hose meets the side of the head around were the vtec selinoid is. thgere is a 12 mm nut coming out of the thermostat housing. it has a funnylooking top. that is the bleeder.warm your car up and crack it open. just alittle bit. let coolant come threw it for a few. that is how u bleed it...
Old Mar 1, 2007 | 11:27 AM
jdmlude5
Guest
Posts: n/a
im sure my prob. aint the same. i just threw a cel. fuel system supply...any ideas any 1.
Old Mar 1, 2007 | 04:50 PM
check fuel filter, when was the last time you change it?you can also try lucas injector cleaner. sometimes it could be little stuffs we dont notice.
i juz clean mine today, its good. it still have some but it goes away easy. im doing some test drives later. hopefully its over.
if its fix, i starting saving for 5 speed tranny.
Old Mar 1, 2007 | 05:01 PM
jdmlude5
Guest
Posts: n/a
now that i think about it i have not changed my filter in years. thanks ill give it a shot tomorrow and let ya no how it went...
Old Mar 1, 2007 | 05:05 PM
SKDRCR's Avatar
For some reason with the stock FPR, my plugs were always lean and the fuel pressure was low on my car. I switched my B&M fpr over and the fuel pressure jumped
up to where it should be.
Old Mar 1, 2007 | 08:47 PM
JDMLude850's Avatar
mine did that for about a year, bought a fitv adn a aicv. about 500 bucks later all it was, was a intake manifold gasket. thanks to everyone that says the others. a woppign $10 and it was fixed
Old Mar 2, 2007 | 12:02 AM
question about bleeding, do i open it and let all the coolant drain or juz a little bit. this is new to me so im going to ask some questions.
i made some test drives, it doesnt do it anymore much like before, but for some reason i get a CEL whenever i floored it staying on D4. but all i do is turn it off and start again.
this other guy in here saying its the intake manifold gasket, we could try that too.
im going to try to change the gasket.
goodnight guys or good morning.
Old Mar 2, 2007 | 12:33 AM
PWRDbyHseries's Avatar
well yesterday i took my FITV out and cleaned it, so i guess today im goin to spray starting fluid around the intake check for leaks and if i dont find ne then ima take the FITV back off and turn it down some more, and IF that doesnt helo then i guess the last resort will to be buy a new 1.... that IDLE is annoying, and it only does it if its cold out, if the temp outside is nice and warm i dont think that it does it, but when i start my car in the morning for work all i hear is that idle....
Old Mar 2, 2007 | 01:31 PM
jdmlude5
Guest
Posts: n/a
just alittle bit....
Old Mar 2, 2007 | 05:08 PM
thanx dude, eversince i joined this forum, i learned more stuffs about h22. how's your car dude? have you tried changing your fuel filter? keep me inform about whats happening.
im goin to change my intake manifold gasket and see how it works.
Old Mar 2, 2007 | 05:49 PM
jdmlude5
Guest
Posts: n/a
nah have not changed it yet. prob gonna do it tomorrow
TegraD
May 15, 2009 02:55 PM
twentyhurtz
Dec 5, 2008 07:30 PM
vtecmike1
Jul 30, 2004 02:20 PM
V-Thang
Acura TL, RL & ZDX
Feb 24, 2004 02:10 PM
FourthGenHatch
Apr 29, 2002 11:08 AM
