Compression test on a H23
Old Jan 24, 2003 | 11:15 AM
Chinchilla's Avatar
Default Compression test on a H23
I going to be compression testing my 93 SR tomorow and was wondering what kind of numbers I should expect? also how far off can one cylinder be without having to worry?
Old Jan 24, 2003 | 07:14 PM
Chinchilla's Avatar
Default Re: Compression test on a H23 (Chinchilla)
anyone?
Old Jan 25, 2003 | 08:24 AM
PrecisionH23a's Avatar
all of your numbers should be within 10psi of each other, i cant remember what 9.8:1 compression yields but im thinking 190ish? Im sure someone knows...
Old Jan 25, 2003 | 08:56 AM
LudeyKrus's Avatar
Default Re: Compression test on a H23 (GudeH23a)
well, mine had 100k miles on it when I did mine a few months ago, and I pulled around 160's; people said that was alright for my motor, but I couldn't get a web page to show what the numbers should be.
Old Jan 25, 2003 | 09:59 AM
BoostedH23a1's Avatar
Default Re: Compression test on a H23 (LudeyKrus)
198 low and 205 high for me..
Old Jan 25, 2003 | 01:51 PM
LudeyKrus's Avatar
Default Re: Compression test on a H23 (BoostedH23a1)
Dang, was that newly rebuilt? I guess I need to look into some new rings/pistons....
Old Jan 25, 2003 | 04:32 PM
Chinchilla's Avatar
RESULTS:
Cylinder# 1 2 3 4
PSI 210 210 213 212
w/ cap full of oil droped into cylinder
Cylinder# 1 2 3 4
PSI 260 250 245 245
So does this mean I my seals are gone?
Old Jan 26, 2003 | 06:11 PM
Chinchilla's Avatar
do you guys think I should get a leak down test?
Old Jan 26, 2003 | 07:01 PM
slow02ss camaro's Avatar
My 2000 H22a4 with 6,000 miles pulled a 210, 200, 200, 200....so those numbers are pretty damn good for an h23
Old Jan 26, 2003 | 07:19 PM
Default Re: Compression test on a H23 (slow94accord)
try a leak down... those are very low numbers...
Old Jan 26, 2003 | 07:25 PM
LudeyKrus's Avatar
210 is a low number?! Good gawd, what should they be then?!
Old Jan 26, 2003 | 07:38 PM
Chinchilla's Avatar
low numbers? on a 100,000mile stock engine?
Jos3ph
Jan 14, 2008 09:45 AM
BLACK_DEL_SOL
Sep 20, 2004 09:08 AM
greenli0n25
Jan 26, 2004 07:29 AM
Chubz
Jun 27, 2002 02:00 PM
Halo
May 5, 2002 07:03 PM
