compression results....
Old Jul 17, 2001 | 07:34 PM
1992milanoprelude's Avatar
New User
Default compression results....
I changed my plugs today..and decided to do a compression test.. i want you guys to help me understand if the below figures are ok.. and what numbers would i see if they were bad... i am hoping these numbers reflect good.. my cars is a 92 si.. and i jsut had the head redone due to some type of aluminum shrapenel getting in one of the chambers...
1: 155
2: 160
3: 150
4: 160
Old Jul 17, 2001 | 08:17 PM
boomslang's Avatar
Default Re: compression results.... (1992milanoprelude)
If you did the test properly and your valves are adjusted right, those numbers are low.
The engine needs to be warm for the test, pull the ecu fuse out and hold down the gas pedal while cranking, crank the motor about 8-10 times.
My '95 turbo Si tested at 210, 210, 210, 195.
Old Jul 18, 2001 | 01:11 PM
New User
Default Re: compression results.... (Inlinefour)
yea.. i found out about the engine temp and the wot.. after reading some info i thought that it was low.. i will do the test again and hope for the best... thanks
acmoc
15
Jan 10, 2012 08:34 PM
Junkie
Mar 22, 2008 12:21 PM
DRKSol
Jan 18, 2006 08:23 AM
aziantegger10
Mar 25, 2005 02:47 PM
thao4life
Oct 8, 2002 03:46 PM
