compression questions????
Old Oct 19, 2002 | 10:42 AM
pitbull97's Avatar
Default compression questions????
whats up guys, Hey Im about to get the jrsc and I have about 72,000miles on the car now, its a 97, and I checked the compression the other day, and starting from 1 to 4 I had 110, 110, 130,130... is that normal, someone let me know, thanks, Mike
Old Oct 19, 2002 | 10:57 AM
laughinxxx's Avatar
New User
Default Re: compression questions???? (pitbull97)
I think you did the test wrong. You should have around 200-220.
Old Oct 19, 2002 | 03:19 PM
pitbull97's Avatar
Default Re: compression questions???? (laughinXXX)
im not sure how i did it wrong though, have u done it.... i think there is only 1 way u can do it right..
Old Oct 20, 2002 | 06:36 AM
pitbull97's Avatar
Default Re: compression questions???? (PreloodDude)
see i just took the coil wire off and let it dangle there, maybe thats why it didnt work, but then i started at 1, took the plug wire out and screwed in the pressure gauge and thats it.............
Old Oct 20, 2002 | 10:06 AM
Quiklude's Avatar
if you dont know you are suppost to have the throttle body at WOT (wide open throttle), you will get inaccuarate readings if not. Actually did a compression test on my buddys dads ls/vtec (shaved head, thin gasket, and stock bottom) and we got 230 all the way across.
Old Oct 20, 2002 | 01:01 PM
pitbull97's Avatar
Default Re: compression questions???? (Quiklude)
I thought u were supposed to turn the key,and that was it, I didnt know the car was supposed to be running, thats goofy..........Im all jacked up or something..lol
Old Oct 20, 2002 | 02:02 PM
Quiklude's Avatar
no you are suppost to pull all the spark plugs then install the compression gauge in one cylinder, then have some one crank the motor with the throttle wide open
Old Oct 20, 2002 | 02:48 PM
pitbull97's Avatar
what do u mean with the throttle wide open, just crankin on the motor? I think i basically did that, I just didnt pull all the spark plug wires out, I just did one at a time...... Hmmmmmmmmmm
Old Oct 21, 2002 | 07:44 AM
GAperformance's Avatar
New User
Whoa, Whoa, you don't add oil unless you get bad compression in a cyl. Here is a good quick summary:
Pull all the plug wire out, then take all 4 spark plugs out and be sure the line them up in order so you put them back into the same cylinder. Then pull the fuel pump fuse under the dash. Screw the Comp. Tester into the 1st cylinder then push clutch in and push gas pedal all the way down and crank about 9 times. On average you should be around 180-220. If any cylinder is 25% lower than the highest cylinder out of the 4 then you need to pour a cap full of oil into the cylinder and then retest it. If it goes up to where the others are then you have leakage. IE don't superhcarge it. Just by looking at your number you are fine.
Old Oct 21, 2002 | 01:42 PM
BoostedH23a1's Avatar
Default Re: compression questions???? (bkw97lude)
ouch i have 210 on my h23 not WOT
umair
Dec 7, 2009 10:37 AM
lee0149
Feb 6, 2009 10:33 AM
MrMug3n
Jul 14, 2008 04:02 AM
EJ8beast
Nov 27, 2006 05:58 PM
dirtySOHC's
27
Jun 11, 2002 05:38 PM
