code 9???
Old Nov 2, 2005 | 08:40 PM
high_revs's Avatar
Default code 9???
so i have a check engine light...i check out the code and it checks out #9....now i look and my code list and see thats its "cylinder sensor".....so after i find this im stumped....wtf does it mean?!! some1 told me it was probably the pick up in the dizzy, but if any1 knows for sure, let me know...
Old Nov 3, 2005 | 05:11 AM
kulrevon's Avatar
Default Re: code 9??? (SB tuning)
this is on an obd1 right?
it should just be one of the pick ups I believe. do you have another dizzy to try.
Old Nov 3, 2005 | 10:11 AM
high_revs's Avatar
yeah obd1...i dont have another internal coil distributor, but i do have a good external...would i be ble to take out the pick ups from the old one to put in my internal coil distributor???
Old Nov 3, 2005 | 10:24 AM
kulrevon's Avatar
Default Re: (SB tuning)
yeah just dont mess up the wiring when you pull everything out of the dizzy
Old Nov 3, 2005 | 10:37 AM
high_revs's Avatar
well i changed the ignitor already, it went bad last week...and wiring came out good, and then all of a sudden i got this code, so wiring shouldnt be an issue..lol...i'll let you know how it goes.
Old Nov 3, 2005 | 11:07 AM
staticrex's Avatar
When I got a code 9 I ended up having to replace the distributor.
Old Nov 3, 2005 | 01:37 PM
high_revs's Avatar
Default Re: (staticrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex &raquo;</TD></TR><TR><TD CLASS="quote">When I got a code 9 I ended up having to replace the distributor. </TD></TR></TABLE>
lucky enough for me i got sapare parts...but i cant figure how to take it apart
Old Nov 4, 2005 | 04:21 AM
kulrevon's Avatar
Its not that hard. get a flat head and phillips screw driver and your set. pull out all internals switch the one you need. you can tell by color or wires. and them put it back in. simple
Old Nov 4, 2005 | 04:53 AM
high_revs's Avatar
i cant figure out how to remove the two bottom pick ups...i've removed every damn screw and they are loose, just no space to take them out! wtf?! lol
Old Nov 4, 2005 | 11:22 AM
high_revs's Avatar
bump for help
wakaranai
Feb 5, 2008 03:54 PM
mike9571
Jul 9, 2007 09:05 AM
G0crxG0
Dec 3, 2006 02:38 PM
SolidSpruce
Sep 23, 2003 02:28 PM
