code 22 vtec pressure switch need help
Old Feb 10, 2007 | 08:58 AM
preludefien
Guest
Posts: n/a
Default code 22 vtec pressure switch need help
umm ok i have the jdm h22a vtec engine. i was running the p14 for a while til i got the money to get the p13. so i finally got it and its throwing code 22..i have triple checked the connections. code 22 is the pressure switch correct. someone said to clean the solenoid but i dont know how to ge it of..any suggestions or could anyone tell me how to get it off..also would this cause my car to run a little sluggish...
Old Feb 10, 2007 | 12:55 PM
preludefien
Guest
Posts: n/a
Default Re: code 22 vtec pressure switch need help (preludefien)
any ideas
Old Feb 10, 2007 | 01:02 PM
SteveoBA8's Avatar
service manual, flowchart.
Old Feb 10, 2007 | 04:21 PM
JasonST's Avatar
Default Re: code 22 vtec pressure switch need help (SteveoBA8)
What year is the engine and ecu? Also, check ur oil level, of course, if u haven't already.
Old Feb 10, 2007 | 08:52 PM
M2B4's Avatar
Default Re: code 22 vtec pressure switch need help (JasonST)
yeah top off on oil, unplug then unbolt the solenoid from the block. theres a filter inside it make sure thats not clogged.
Old Feb 11, 2007 | 09:25 AM
preludefien
Guest
Posts: n/a
Default Re: code 22 vtec pressure switch need help (M2B4)
if its clogged up will that cause it to throw the cel
Old Feb 11, 2007 | 09:45 AM
M2B4's Avatar
yes
Old Feb 11, 2007 | 10:43 AM
preludefien
Guest
Posts: n/a
ok so i took the pressure switch off but still couldnt get the solenoid off..any clues..maybe i not catching one of the bolts...arent there just three bolts
wernhersey
Apr 15, 2007 07:48 AM
lshatch92
Mar 27, 2006 10:04 AM
scythemk
Jan 29, 2006 10:10 AM
drudy
Aug 7, 2005 05:59 AM
slackeR1366
Dec 29, 2001 12:06 PM
