Code 20 ELD
Is there a place were i can get this code fixed. I have a 92 CDM vx with jdm h22.
The honda dealership just gives me a bad time because it's a swap.
H-T here says that it is in the under hood fuse box but i am lost.
I would glady pay to it get fixed but i dont know were to go. I live nor cal too.
Maybe a diagnostic shop???
First this code will not appear (I mean a check engine light). It's stored in ECU memory though.
ELD is a device mounted under the underhood fuse box.
Second you have to use USDM underhood fuse box and it will fix the problem.
The only fix for a failure of the ELD is to replace it. You can only buy it as part of the underhood fuse panel for several Honda cars (such as the CRX). Many salvage yards can get this part, otherwise your only option is a dealer.
I have this code on my swap too. From my understanding, 88-89 Preludes don't have ELD so there's nothing to hook it up too (but 90-91's had it I think).
But you're right, it won't actually show the engine light...it only shows up when you jumper the ECU to show what's in its memory.
Can someone be a little more specific though, it'd be nice to get rid of this code if possible.
But at the same time, does the P72 or P28 have the error code? I'm thinking of doing P72 and going Hondata (and getting rid of the EGR) so if this is the case, I'll just wait.
CRX Hooptie
17
Feb 19, 2011 12:14 AM
racerjohn
Apr 12, 2008 11:05 AM
