clutch drops to floor?
Old 01-08-2006, 04:10 PM
ekim952522000's Avatar
Default clutch drops to floor?
hey guys in my 98 prelude every once in a while the cluth will go down and stay down and the car wont go back in gear than I have to pull it up with my foot and pump it a couple of time and it works again? I checked the cluth fluid and it's full any ideas what it could be?
Old 01-08-2006, 04:17 PM
VTecLude1994's Avatar
Default Re: clutch drops to floor? (ekim952522000)
Air bubble?
PreludeX24's Avatar
most likely you got some air in there.
you gotta bleed the clutch. There's a little nipple on the slave cylinder, loosen it up, uncap the clutch fluid reservoir, pump it once or twice, check the reservoir to make sure theres still fluid in there and not sucking in air. keep doing it until its good. then tighten up the nipple and your set.
Lareau
07-20-2016 06:58 AM
tbuck23
04-03-2007 01:27 PM
stealth89hatch
16
02-18-2005 10:53 PM
xerox445
10-20-2003 10:15 AM
PatrickGSR94
12-08-2002 06:36 PM
Quick Reply: clutch drops to floor?
