Changing headgasket Question
Old Jul 14, 2009 | 05:42 PM
m00nr0ck Si's Avatar
Default Changing headgasket Question
Im fixing to change my head gasket and head bolts tommorow along with a bunch of seals and o-rings...question is ,do i need to have the head resurfaced even if it never got hot? I just noticed the coolant dissapearing and checked my spark plugs to find coolant on cylinder #1 plug....the car would sometimes sputter on start up and smell really sweet like coolant ....
BTW: I completely cleaned the head and block surface to a shine and plan on using copper spray on the gasket
Old Jul 14, 2009 | 11:14 PM
lude98SH's Avatar
Default Re: Changing headgasket Question
Check it for warpage using a straight edge and feeler gauge. If its in spec clean it up and you should be ok. However, if I was taking the time to pull the head and it was my own vehicle I would probably deck it for peace of mind. But if money is tight, like i said, you should be fine without it.
Old Jul 15, 2009 | 01:20 PM
thanx man.....
flozella
Aug 30, 2014 07:20 PM
thechad888
Dec 1, 2013 08:56 AM
2oh6civic
Oct 21, 2007 06:56 PM
prelude1911
Jun 5, 2007 07:55 AM
JTCdudeman
Sep 29, 2005 05:42 AM
