CEL's on, no VTEC... common problems?
Old Dec 21, 2005 | 01:10 PM
four o two's Avatar
Default CEL's on, no VTEC... common problems?
Hey guys, my CEL came on this afternoon and I noticed that VTEC no longer engages. Any ideas on the most common problems that would cause this?
Oil level's fine, has recently been changed, my car's not modified at all (bone stock, never over-revved etc etc) 115,000 miles on the clock...
Any ideas?
Old Dec 21, 2005 | 01:13 PM
IHateJDM's Avatar
Default Re: CEL's on, no VTEC... common problems? (four o two)
Do you know how to pull the CEL code? I would start there.
Old Dec 21, 2005 | 01:25 PM
98vtec's Avatar
moderator emeritus
Default Re: CEL's on, no VTEC... common problems? (IHateJDM)
yep...get the code
Old Dec 22, 2005 | 08:33 AM
four o two's Avatar
2 longs, 2 shorts, so code 22, or "VTEC System Malfunction"... any ideas where to go from here?
Old Dec 22, 2005 | 08:52 AM
roller3804's Avatar
Default Re: (four o two)
-VTEC Solenoid Valve
-Open or Short in VTEC Solenoid Valve circuit
-VTEC Pressure Switch
-Open or Short in VTEC Pressure Switch Circuit
-ECM
those are the first things youll need to troubleshoot.
Old Dec 22, 2005 | 09:45 AM
four o two's Avatar
Default Re: (camrann)
Yeah, I see that on the site I read. Maybe a little help on how to troubleshoot these things?
Old Dec 22, 2005 | 10:21 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by four o two &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I see that on the site I read. Maybe a little help on how to troubleshoot these things? </TD></TR></TABLE>
you said your oil level is fine, right?
check the wiring.
solenoid is one wire, goes to A4 on ecu
Pressure switch is 2 wires, hot to D6, ground to A26.
check vtec solenoid screen to see if its clogged (pull solenoid off the head).
Old Dec 22, 2005 | 10:41 AM
SteveoBA8's Avatar
Default Re: (IHateJDM)
Code 22 is vtec oil pressure switch. You can check the pressure switch for continuity to make sure its ok, then check your wiring, you might want to invest in a dvom.
Old Dec 22, 2005 | 10:48 AM
four o two's Avatar
Default Re: (SteveoBA8)
Can you spare the acronyms and speak English please? I have a digital volt meter if that's what you're saying.
Old Dec 22, 2005 | 11:44 AM
SteveoBA8's Avatar
dvom= digital volt ohm meter, make sure the ground for the switch is clean and good, i can email you the cel flow charts if you want
Old Dec 22, 2005 | 11:47 AM
Iamcuddles's Avatar
I got the same error, however v-tec still works, just not as strong.
barone
Oct 25, 2009 02:33 PM
ghettoSi
Jan 11, 2008 11:39 PM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
dkboyny11
Jun 2, 2005 03:45 PM
VTC_CiViC
Nov 17, 2004 09:05 PM
