CEL woes.. code 1 and code 43
Old 06-22-2005, 10:25 AM
DarkBB4's Avatar
Default CEL woes.. code 1 and code 43
1995 Prelude vtec
OBD1
code 1 : o2 sensor most likely due to SEA FOAM
code 43? Fuel supply?
can i drive the car? it drives fine!!?!?
im replacing the o2 asap, but will the other cel go off too?
Old 06-22-2005, 12:02 PM
DarkBB4's Avatar
Default Re: CEL woes.. code 1 and code 43 (DarkBB4)
is it ok to drive the car?
the CEL comes on after bout 5 minutes of drviing
Old 06-22-2005, 02:09 PM
flip1199's Avatar
you'll be fine driving around like that, but your gas milage wont be that great. it shold go away once u replace your o2.
Old 06-22-2005, 02:12 PM
DarkBB4's Avatar
Default Re: CEL woes.. code 1 and code 43 (flip1199)
just reset ecu and drove a round for ab it.. the light didn't come on for a while.. then it cam eon so read the code
ONLY code 43!?!
wierd?!?!
Old 06-22-2005, 03:26 PM
Jagan'92's Avatar
Sea Foam
Just kidding, I had the same issues when I foamed my car. I pulled and cleaned the O2 sensor, and used some techron gas for a while and it eventually stopped popping up.
Old 06-22-2005, 03:47 PM
junbb1's Avatar
Default Re: CEL woes.. code 1 and code 43 (Jagan'92)
code 43 is a bad o2 sensor. trust me, seafoam or not.
Old 06-22-2005, 04:04 PM
jzobie's Avatar
Default Re: CEL woes.. code 1 and code 43 (junbb1)
after i replaced my O2 sensor i got code 43 also it comes on if the car is started cold once it warms up. If you turn the car off and back on again it doesnt come back on and from doing that my gas milage is the same. In the service manual it states that it is most likely a wiring problem and they give a flow chart on how to fix the problem but i havent gotten around to it yet.
Old 06-22-2005, 06:21 PM
bgm93srv's Avatar
When I used a Bosch replacement o2 I still got the code. Once I switched to the Ntk the code went away. Just be careful what O2 sensor you get or it might not fix the problem.
Old 08-26-2005, 07:05 AM
DarkBB4's Avatar
Default Re: (bgm93srv)
ij ust replaced my o2 sensor and I still get teh code 43 after drviign for 15 minutes or so..
im pretty sure its killing my gas milege
Old 08-26-2005, 07:34 AM
syntax.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgm93srv &raquo;</TD></TR><TR><TD CLASS="quote">When I used a Bosch replacement o2 I still got the code. Once I switched to the Ntk the code went away. Just be careful what O2 sensor you get or it might not fix the problem.</TD></TR></TABLE>
+1 for same experience
Old 08-26-2005, 08:35 AM
DarkBB4's Avatar
Default Re: (syntax420)
alright reset battery and i started it up
the car is running like crap
idles is all wierd
it studders like therse way to much fuel
NO CEL yet
its an OEM o2 sensor too
what should i do!
Old 08-26-2005, 10:12 AM
DarkBB4's Avatar
Default Re: (DarkBB4)
Old 08-26-2005, 12:30 PM
fscot's Avatar
nm
Old 08-26-2005, 12:35 PM
LudeyKrus's Avatar
43 can be a few things; it's the catch-all fuel code.
On my last motor, I would occasionally get 43 out of nowhere, but it drove fine and would go away for a long time if I reset it. If i tuned the VAFC's narrow-throttle settings and it threw the code as well.
My new motor is throwing it now, and it sounds like an injector cutting out when I give it gas. The manual says it can be bad gas, an injector, or the FPR. I've also heard of the fuel filter causing this problem.
Go figure.
Old 08-27-2005, 09:31 AM
DarkBB4's Avatar
Default Re: (LudeyKrus)
maybe my vafc is fking up im not sure
but i want this fixed asap! anyoen else have ideas
EFz6er
11-01-2005 09:39 AM
notfastenough
11-11-2004 04:31 PM
Qwikrex
06-22-2002 12:52 PM
ARACER25
05-15-2002 08:19 AM
Quick Reply: CEL woes.. code 1 and code 43
