CEL help 71, 72, 72, AND 74?!
Old Jul 2, 2007 | 11:47 AM
BB6DR's Avatar
Default CEL help 71, 72, 72, AND 74?!
Ok I dont get it pulled the codes on my 01 prelude and got all four codes! Car runs just fine and those codes indicate a misfire but on all 4 cylinders can that be? Wouldn't I notice a sluggage performance. The CEL went off last night out of the blue but appeared again. Could this be a sensor problem if so which one?
I have already replaced the spark plugs, O2 sensor, and cleaned my egr valve.
Any help would be greately appreciated.
Old Jul 2, 2007 | 12:02 PM
vinuneuro's Avatar
Default Re: CEL help 71, 72, 72, AND 74?! (BB6DR)
Plugs, Dist cap/rotor, plug wires, fuel filter, valve adjustment.
AFTER that, look here:
https://honda-tech.com/zerothread?id=2016969
Old Jul 2, 2007 | 06:49 PM
BB6DR's Avatar
Plugs were done, dist cap/rotor were done about 50k ago. Perhaps i'll try the fuel filter and valve adjustment...
Old Jul 2, 2007 | 07:13 PM
mgags7's Avatar
Its still throwing the codes after the new 02 sensor and all?
That code can come from many different things, my car needs a new o2 sensor for sure right now, but it still throws this code sometimes, only on the highway at 65-70mph, very odd, its right around 4k rpm with my gearing, so maybe the IABs not being hooked up right now might have something to do w/that.
We shall see.
Old Jul 2, 2007 | 08:11 PM
JBirch_97Prelude's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Its still throwing the codes after the new 02 sensor and all?
We shall see.</TD></TR></TABLE>
I am having the same problem, and I can't understand why it only happens around 65-70mph. Also, I was driving in 5th gear with the cruise control set just below 80mph and I was throwing codes every 5 seconds. The weird thing is there was no noticible change in power or rpm's. I was thinking about a valve job but I don't know if that will help since I am running a H22A, instead of a H22A4.
Old Jul 2, 2007 | 11:08 PM
prelude1897's Avatar
Default Re: (JBirch_97Prelude)
I had the same exact problem for a little while. What I did was change the plugs, cap and rotor, valve adjustment, clean the EGR and IAC valve, ran a little sea foam, and it cleared it up...
Old Jul 3, 2007 | 10:12 AM
Default Re: (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">I had the same exact problem for a little while. What I did was change the plugs, cap and rotor, valve adjustment, clean the EGR and IAC valve, ran a little sea foam, and it cleared it up...</TD></TR></TABLE>
Well the only thing I have not done is a valve adjustment!
Old Jul 3, 2007 | 10:36 AM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6DR &raquo;</TD></TR><TR><TD CLASS="quote">Ok I dont get it pulled the codes on my 01 prelude and got all four codes! Car runs just fine and those codes indicate a misfire but on all 4 cylinders can that be? Wouldn't I notice a sluggage performance. The CEL went off last night out of the blue but appeared again. Could this be a sensor problem if so which one?
Any help would be greately appreciated.</TD></TR></TABLE>
i bet you 1000 dollars that your codes aren't o2 lean or rich. I just went thru this, because you doing the obd2 blink codes, your getting a 71 72 and 74. when in reality if you checked it with a scan tool it would tell you cylinder 1 missfire cylinder 2 misfire and ignition system malfucntion. change you plugs cap rotor and wires, like v said above.
whiteboy9191
25
Feb 18, 2013 03:02 PM
OhWUNshlude
Nov 29, 2007 09:37 PM
Topshot
Oct 8, 2007 04:13 PM
92BlackSi
14
Apr 8, 2005 11:00 AM
