CEL code write-up
Old Sep 22, 2007 | 12:43 PM
prelude_93vtec's Avatar
Default CEL code write-up. How to and Code List.
So i decided to make a thread for CEL codes so instead of everyone asking what this code is and that code is. So I'm going to start off by telling people how to check their code.
First, find the diagnostic connector, which is a two wire blue connector found behind the console by the drivers side feet or the passengers side feet. Short out the connector by putting some sort of wire into them (ex. Paper clip or just a copper wire). Then, turn the ignition to On but not start. The check engine light on the dash will flash the problem codes. If there are more than 1 problem, a different code will subsequently follow the first after a brief pause.
There are two types of flashes - short and long, which are combined to represent number codes. Each short flash indicates 1 unit and each long flash represents 10 units. Problem codes 1 - 9 are indicated by 1 - 9 flashes, problem codes 10 - 90 use 1 - 9 long flashes. If the code is more than 9, the long flashes will start first before the short ones. The codes will continue to repeat as long as your ignition is on.
After you get the code number, you have to find out what the code actually means.
<U>Here's the list. CEL code 1 to CEL code 92</U>
Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
Oxygen Sensor "B"
MAP Sensor (Manifold Absolute Pressure)
CKP Sensor (Crankshaft Position Sensor)
mechanical problem / disconnected piping
ECT Sensor (Engine Coolant Temperature)
TP Sensor (Throttle Position)
TDC Sensor (Top Dead Center)
CYP Sensor (Cylinder)
10
IAT Sensor (Intake Air Temperature)
12
EGR Lift Sensor (Exhaust Gas Recirculation)
13
BARO Sensor (Atmospheric Pressure)
14
IAC Valve (Idle Air Control)
15
Ignition Output Signal
missing or defective ignition output signal
16
Fuel Injector System
defective circuit or unplugged / defective fuel injector
17
VSS (Vehicle Speed Sensor)
19
Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20
Electrical Load Detector
21
VTEC Solenoid Valve
22
VTEC Oil Pressure Switch
defective circuit or unplugged / defective oil pressure switch
23
KS (Knock Sensor)
30
Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
31
Automatic Transmission Signal "B"
41
Primary Oxygen Sensor - Heater
circuit malfunction
43
Fuel Supply System
defective or malfunctioning fuel supply system
45
System Too Lean or Too Rich
malfunction in the fuel monitoring systems
48
LAF Sensor (Lean Air Fuel)
54
CKF Sensor (Crankshaft Speed Fluctuation)
58
TDC Sensor 2 (Top Dead Center)
61
Oxygen Sensor, Heated - Sensor 1 (Primary)
high voltage, low voltage, or slow response
63
Oxygen Sensor, Heated - Sensor 2 (Secondary)
65
Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
67
Catalyst system Efficiency Below Threshold
malfunctioning or defective catalyst system
70
malfunction with the automatic transmission controls
71
Cylinder 1 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
72
Cylinder 2 Misfire or a Random Misfire
73
Cylinder 3 Misfire or a Random Misfire
74
Cylinder 4 Misfire or a Random Misfire
75
Cylinder 5 Misfire or a Random Misfire
76
Cylinder 6 Misfire or a Random Misfire
80
insufficient flow detected
76
circuit range / performance problem
90
Evaporative Emission Control System
leak detected in the fuel tank area
91
Fuel Tank Pressure Sensor
low input
92
insufficient purge flow
Modified by prelude_93vtec at 3:57 PM 9/22/2007
Old Sep 22, 2007 | 12:47 PM
dagle's Avatar
Default Re: CEL code write-up (prelude_93vtec)
its called the search function yO
http://www.c-speedracing.com/faq/05.php
^-- that basically sums up the thread lol
Old Jun 17, 2019 | 09:31 PM
Jallen1843's Avatar
Default Re: CEL code write-up. How to and Code List.
Oxygen Sensor "B"
10
12
13
14
15
16
17
19
20
21
VTEC Solenoid Valve
22
23
KS (Knock Sensor)
30
31
41
circuit malfunction
43
Fuel Supply System
45
48
54
58
61
63
65
67
70
71
72
73
74
75
76
80
76
90
91
low input
92
So my son's 94 Honda Accord with the VTech engine has code 22 and 11 I saw code 22 but didn't see 11 what is that code for? Trying to figure out what we need to do.
his gears D4 constantly flashes and after awhile the check engine light comes on. Apparently the speedometer freaks out sometimes and the Rpm's.
soodominican
Aug 12, 2009 12:48 PM
Zerotls
Nov 17, 2008 09:40 PM
t_dot_SiR
May 2, 2007 04:01 PM
UtahRockabilly
Mar 28, 2004 10:43 AM
b18civic
Feb 18, 2002 03:58 AM
