car is overheating at idle...fans not coming on
Old 08-12-2004, 09:51 PM
sleepy_vtec's Avatar
Default car is overheating at idle...fans not coming on
whenever my car idles for a while, it will begin to over heat. When i start to move it goes back down. I have began noticing that my fan is not coming on. I have checked the relay and it is fine. What else can i check?
Old 08-12-2004, 09:53 PM
killa_lude's Avatar
Default Re: car is overheating at idle...fans not coming on (sleepy_vtec)
i would like to know as well.
Old 08-12-2004, 10:50 PM
BrokeLude's Avatar
Default Re: car is overheating at idle...fans not coming on (killa_lude)
Fuse, motors, sensors...
Old 08-13-2004, 05:00 AM
Sephro's Avatar
Default Re: car is overheating at idle...fans not coming on (BrokeLude)
Mine did that once and it was the plug that is right at the thermostat housing. It wasn't making a good connection. Check that. it's prolly the problem.
Old 08-13-2004, 08:36 AM
Default Re: car is overheating at idle...fans not coming on (Sephro)
anytime it overheats, can i turn on my a/c and let it cool off. will the compressor fan still run? My compressor is not hooked up because it went bad, so i unhooked the compressor. But if i hit the a/c button, will that only turn on the fan? That is sort of confusing, but hopefully someone can understand that.
Any have a GOOD a/c compressor that they would like to get rid of?
Old 08-13-2004, 08:10 PM
anyone else?
Old 08-14-2004, 02:21 AM
viperguy's Avatar
No you don't want to hit the A/C when it's overheating. You need to turn the heater on (all the way). If your fan is not turning on, check the fuse and the temperature sensor(located on the thermostat housing)....it's most likely the sensor...
Old 08-14-2004, 02:52 AM
TimeRacer's Avatar
Default Re: car is overheating at idle...fans not coming on (viperguy)
In this case the AC might actually help as it will turn on the AC fan contrasts to no fan at all at idle.
But I'd check the fan switch to see if it's working or not and to ensure that you don't have a break anywhere in your connections along the line to the rad fans.
Old 08-14-2004, 06:15 AM
killa_lude's Avatar
i have a ac compressor if you want one. make an offer.
Old 08-14-2004, 06:27 AM
mgags7's Avatar
definately check the thermostat and the temp sensor on the thermostat housing. If the sensor is bad, the fans wont turn on b/c they dont get the warning that its too hot. Your car begins to cool when you start driving b/c you start blowing lots of air over the radiator, so it cools the coolant down. Definately check that sensor and if its bad, you should be able to use one off any honda engine, but make sure of that first. If you need it, i have an ac compressor and a temp sensor. Im not completely sure the compressor is good though, it came off my swap, so i never have used it, but the company that sold me the motor says it should work....let me know...
Old 08-15-2004, 12:19 AM
Default Re: car is overheating at idle...fans not coming on (mgags7)
i have another sensor out of an h23 intake manifold i have sitting around. IF that sensor were to go bad, wouldnt it throw any sort of code?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">definately check the thermostat and the temp sensor on the thermostat housing. If the sensor is bad, the fans wont turn on b/c they dont get the warning that its too hot. Your car begins to cool when you start driving b/c you start blowing lots of air over the radiator, so it cools the coolant down. Definately check that sensor and if its bad, you should be able to use one off any honda engine, but make sure of that first. If you need it, i have an ac compressor and a temp sensor. Im not completely sure the compressor is good though, it came off my swap, so i never have used it, but the company that sold me the motor says it should work....let me know...</TD></TR></TABLE>
how much do you want for the compressor? i am in nashville, tennessee
Old 08-15-2004, 04:53 PM
ok, if it is the sensor located in the thermostat housing, wouldnt my car always read as being cold? Would it not have a reading of the temp at all or is that the temp sensor that controls when the fans come on?
Old 08-16-2004, 01:09 PM
92hondalude's Avatar
Is the fuse for the Fan in the fuse box inside the car or some place other. What will it be called on the fuse box if so? I have h23a 92 prelude si.
Old 08-16-2004, 06:29 PM
skiier's Avatar
Ever wonder why it is on a hot day that people tell you your "fan is still running" as you walk away from your car? Did it ever occur to you that the engine temperature sensor (and it's gauge) might be a different control component than the temperature "switch" that turns on your main cooling fan?
Here is what you have. The main cooling fan is directly connected to a live battery connection at all times and is controlled by a temperature switch located within the radiator. This switch simply "closes" on rising temperature and "opens" on falling temperature. You cannot remotely turn on or turn off the main fan and it is independent of the ignition key switch. This system is in your car so that you won't warp that precious aluminum engine block of yours and come back to Honda looking for a warranty replacement motor.
Locate the temp switch for the main fan and pull off the connector. "jumper" the connector and see if the fan comes on. If the fan comes on replace the temp switch. If the fan doesn't come on check for power at the connector ( to gnd). If you have power at the connector than replace the fan.
Don't mess with an overheating problem! It only takes a few minutes of driving to damage an overheated ALUMINUM engine beyond repair. Imagine how much it would cost to replace a motor instead of a faulty temperature switch.
Old 08-17-2004, 06:42 PM
Default Re: car is overheating at idle...fans not coming on (skiier)
you said to locate the temp switch...where would it be for us to locate it!!
Old 08-18-2004, 08:15 AM
93H22ACX's Avatar
you can wire a switch to the fan so when you're at idle you can flip the switch to turn on the fan....
dumb question....have you replaced your thermostat? also check the ECT sensor....
Old 08-19-2004, 10:27 PM
Default Re: car is overheating at idle...fans not coming on (93H22ACX)
i have not replaced anything yet. but would the thermostat cause the fans to not come on?
Old 08-20-2004, 02:45 AM
93H22ACX's Avatar
no.the thermostat would cause your car to either overheat or run cool..check your ECT sensors and fan relays
Old 08-20-2004, 03:02 AM
fastludeh22's Avatar
i just wired my temp sensor wires together. now my fan comes on with the key. that way at the strip i can make the fans be on, but the engine off.
Old 08-20-2004, 03:04 AM
93H22ACX's Avatar
Default Re: car is overheating at idle...fans not coming on (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">i just wired my temp sensor wires together. now my fan comes on with the key. that way at the strip i can make the fans be on, but the engine off.</TD></TR></TABLE>
cool! i wired mine to a little switch so i can flip it on and off
FLCivic
12-18-2007 04:37 PM
Panda hatch
06-15-2006 09:43 PM
Taikonaut
11-04-2005 11:26 AM
THE GAME IS THICK
02-12-2004 04:08 PM
90Accord-R
10-17-2003 07:30 AM
Quick Reply: car is overheating at idle...fans not coming on
