car is draining battery??
Old 01-30-2006, 04:49 PM
dog the bounty hunter's Avatar
Default car is draining battery??
i keep having to bring my battery in for warranty every month, i have a battery relocation kit thats the only thing i can think of that would kill the battery. please help!
Old 01-30-2006, 04:55 PM
1GPlusSH's Avatar
Default Re: car is draining battery?? (dog the bounty hunter)
If you alternator is fine, I'd go back and ground the battery cables at different points.
Old 01-30-2006, 04:56 PM
just got the alternator tested at autozone today and they said its fine
Old 01-30-2006, 10:19 PM
Skidtron89's Avatar
Do you have anything electronic wired directly to the battery? I mean something that is always powered up and is not switched on by the ignition? If so there is your problem if not somethign is staying on. Find it and eliminate the problem. Also if you had rolled your battery in the dirt the iron in the dirt could be causing the battery to discharge across the two terminals slowly which would cause corrosion as well. I know I'm an ******* don't bother telling me I am.
Old 01-31-2006, 01:10 PM
Perfectionist's Avatar
Why would a relocation kill the battery? *If done corrrectly, there's no way.
Maybe you somehow failed to connect the alternator output (recharge) wire to the battery when doing the relocation. That, or what Skidtron89 said.
Old 02-04-2006, 01:07 PM
Default Re: car is draining battery?? (Perfectionist)
ill check
Old 02-04-2006, 10:06 PM
h22PreludeSi's Avatar
first off is it grounded to a solid spot. if so start pulling fuses and probing them to see if you have a parasitic draw anywhere. your looking for the DVOM to read 12v. if any of them are less than that there is your problem. also check the "B" cable to the alternator to see if its even tight. and check the ground and "S" terminal on the alt. (doesnt hurt to just check it out)
Old 02-04-2006, 11:05 PM
prelude_h22vtec's Avatar
mine was draining bad one time, like if i didnt drive it for like 3 days the battery would go dead. it ended up being that the trunk light didnt go off when it was closed. so maybe its something like that.
Old 02-05-2006, 11:50 AM
lude1888's Avatar
Default Stereo system?
Do you have any capacitors wired in maybe from a stereo system?
hkacrkil
Acura TL, RL & ZDX
04-10-2015 02:06 PM
mydogFahey
Honda CR-V & Element
10
03-29-2015 09:59 AM
Integ-boy
11-26-2007 06:12 PM
Syndacate
08-14-2007 05:10 PM
idewson
08-31-2006 11:45 AM
Quick Reply: car is draining battery??
