Cant figure where this leak coming from
Old Nov 30, 2007 | 12:50 PM
Pnoy_ACCLUDE's Avatar
Default Cant figure where this leak coming from
Anyone have ideas where this leak coming from? I cleaned that part 2 days ago so i could spot where that leaks coming from but still could not figure where and not sure if its from under the dizzy. Any other possible part?
Old Nov 30, 2007 | 02:51 PM
nonvteclude's Avatar
Default Re: Cant figure where this leak coming from (Pnoy_ACCLUDE)
looks like your cam cap(seal) or the oring on the distributor
Old Nov 30, 2007 | 03:02 PM
Default Re: Cant figure where this leak coming from (nonvteclude)
Thanks! Either 2 of those seals will be easy to replace? Im guessing valve cover has to be taken off to replace the cam seal right?
Modified by Pnoy_ACCLUDE at 4:35 PM 11/30/2007
Old Nov 30, 2007 | 09:17 PM
correct, the valve cover and then you will have to remove the 4 10 mm bolts from the intake cam cap. its really simple. gl
Old Nov 30, 2007 | 09:24 PM
Hawkze_2.3's Avatar
Yeah, that's probably the distributor o-ring. The cam seal is on the other side (intake cam), but that doesn't rule it out...
Old Nov 30, 2007 | 10:11 PM
Duane_in_Japan's Avatar
Default Re: Cant figure where this leak coming from (Hawkze_2.3)
You should degrease it with some GUNK or better yet with some scrubbing bubbles bathroom cleaner. Get an inspection mirror and see where the real leak is coming from after a drive or two. CLean it up real good first though.
If you remove the cam cap and the valve cover, use RTV where needed during reassembly.
Old Dec 1, 2007 | 07:29 AM
jdmlude5
Guest
Posts: n/a
vtec selinoid maybe?
Old Dec 1, 2007 | 07:37 AM
gogunkergorilla's Avatar
Just pull the distributor and get a better picture, but jack up the right side of the car before pulling it so more oil doesn't come out. I'd suspect the o-ring on the distributor, but it could be the o-ring on vtec solenoid or even the head gasket.
Old Dec 1, 2007 | 07:56 AM
E-Money's Avatar
Default Re: Cant figure where this leak coming from (jdmlude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">vtec selinoid maybe? </TD></TR></TABLE>
i have had numerous leaks come from there
nicko360
Jan 16, 2007 07:56 AM
Out of every "game"
Apr 16, 2006 02:41 PM
diversegsr
Feb 2, 2005 02:49 PM
Matgallis
Jul 10, 2004 09:33 AM
blackdude
Mar 17, 2004 08:55 AM
