Can someone answer this?
Old Sep 1, 2002 | 04:59 PM
KCLude01's Avatar
Default Can someone answer this?
I have a 5th gen lude and sometimes when I come to a stop I hear this creaking noise coming from the rear end of the car. Does anyone know what is the cause of this and if it is a normal problem?
Old Sep 1, 2002 | 06:40 PM
typeSwarrior's Avatar
Default Re: Can someone answer this? (KCLude01)
Sounds like that 'shock-knock' problem. It's supposedly typical in a lot of 5th gens. I don't know anything much about it, maybe someone else can help you...mine doesn't do it so I never read into it.
Old Sep 1, 2002 | 07:21 PM
99_SH's Avatar
Default Re: Can someone answer this? (typeSwarrior)
If its a creaking noise maybe your rear swaybar bushings need to be greased up a bit. If its a knocking sound, then you have the dreded shock-knock.
Old Sep 2, 2002 | 11:11 AM
KCLude01's Avatar
Default Re: Can someone answer this? (99_SH)
I don't think it is shock-knock because it is just a creaking noise. I will check the bushings. Thanks for your help guys. Does anyone know what else I might check?
Old Sep 2, 2002 | 01:37 PM
976's Avatar
976
New User
Teeth of the rear brakes on all cars creak, are you holding your e-brake?
Old Sep 2, 2002 | 02:58 PM
KCLude01's Avatar
Default Re: Can someone answer this? (w00t!)
No, not holding the e-brake. I know it is not the brakes, it sounds like it is coming somewhere from the suspension. It doesn't do it that often, it just does it faintly every now and then.
slateEKsi
15
Aug 10, 2021 04:43 PM
theguy22
30
Oct 28, 2013 07:45 AM
lsvtec101
Honda Civic (2006 - 2015)
11
May 6, 2007 01:20 PM
jdmztrane
Jan 21, 2006 08:08 AM
GuestHead
Oct 24, 2004 07:18 PM
