Caliper Problems
So basically, i bought my car about 2yrs ago, a 1995 honda prelude si, i tried bleeding the brake system a couple days ago, and to my surprise the little **** you turn to bleed each caliper are all seized, i tried spraying Wd-40 but it didn't work and i ended up striping the ***** you turn. So i'm wondering if you guys had any suggestions for buying calipers? should i get stock ones or After-market, and what's the price difference? Also what are the advantages of getting an after market one? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeMOM »</TD></TR><TR><TD CLASS="quote">hawk or brembo, my personal taste.</TD></TR></TABLE>
he's asking for calipers and not pads/rotors from your suggestion.
in your situation, just get the vtec calipers / brackets. a good plug and play swap. 1 inch difference in size too.
don't get any "big brake kits" because you won't / will not need it. its just for looks for the most part.
get some cheap autozone rotors and some good pads and you will be set
Also where can i buy these calipers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc »</TD></TR><TR><TD CLASS="quote">
Also where can i buy these calipers?</TD></TR></TABLE>
i'm guessing you ddin't read my post.
you can't get hawk calipers because there is no such thing. brembos are like ~ 1200+ range. so if you want to spend that much, go right ahead.
som<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 »</TD></TR><TR><TD CLASS="quote">
get some cheap autozone rotors and some good pads and you will be set</TD></TR></TABLE>
what parts do i need to convert to the vtec rotors from a 93-96 honda prelude vtec? i will be putting the parts on my 1995 prelude si
I think they wil be about $50 each with you cores from Autozone. I paid $75 each with cores for my rear calipers a year ago. Rears are more expensive because if the parking brake setup
I totally should have gone that route when I just did my front brakes a couple weekends back );
as I only got the weee si calipers/rotors up front. I wonder how they would take a SI core exchange for a vtec caliper haha.. have to pull a fast eddie.
as I only got the weee si calipers/rotors up front. I wonder how they would take a SI core exchange for a vtec caliper haha.. have to pull a fast eddie.Thread
bosco500
10
Feb 7, 2005 12:18 PM
