building h23 for boost
Old Oct 8, 2006 | 06:29 PM
jwyndsdime's Avatar
Default building h23 for boost
Hello everyone, I am currently doing research on engine components for my h23 that I am going to turbo.
I am probably going to buy the following:
Wiseco dish pistons
Crower turbo camshaft
crower billet rods (really expensive, but not much of a choice)
Complete KMS valvetrain(valves, retainers, springs, and Blockguard)
Anyone have any opinions on these products? good or bad?
ANY info would help!!!
Old Oct 8, 2006 | 08:11 PM
nonvteclude's Avatar
Default Re: building h23 for boost (jwyndsdime)
you should check out the faq's
but things to add would be sleeves, frm doesnt like forged pistons. and last i checked the h23 was a closed deck so you wouldnt need the blockguard. you will also need a good engine manegment
Old Oct 8, 2006 | 10:44 PM
Hawkze_2.3's Avatar
Eh, you don't need turbo cams to make a lot of power, and from what I've read I would not use KMS stuff personally. For valvetrain go Rocket w/ Supertech valves if you want aftermarket.
Do more research and you'll see you have to sleeve your block to run forged pistons.
Old Oct 9, 2006 | 03:11 AM
GrimLude's Avatar
good choice on rods and pistons though!
Old Oct 9, 2006 | 03:38 AM
hu's Avatar
hu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwyndsdime &raquo;</TD></TR><TR><TD CLASS="quote">Hello everyone, I am currently doing research on engine components for my h23 that I am going to turbo.
Wiseco dish pistons
Iirc, you gain midrange with Crower Turbo Cams but lose as much as 40-60 on the top end. Look at the forum on evans-tuning.com for more detailed info. I would stick with the stock cam.
Old Oct 9, 2006 | 06:18 AM
alterdcreations's Avatar
Default Re: building h23 for boost (hu)
try mahle pistons with the crower rods. i have seen people run 15+ on the stock sleeves (no resleeving )
Old Oct 9, 2006 | 09:04 AM
GrimLude's Avatar
Default Re: building h23 for boost (alterdcreations)
do not use those mahle pistons on your stock bore!!! Thats asking for problems!!
Old Oct 9, 2006 | 10:39 AM
shutta's Avatar
are we talking about the mahle "gold" piston that work ok with frm or just regular forged mahle pistons?
Old Oct 9, 2006 | 01:38 PM
GrimLude's Avatar
Default Re: (shutta)
the ones that supposedly work with frm
Old Oct 9, 2006 | 03:08 PM
95greenlude's Avatar
Default Re: (GrimLude)
I PM'd Anthony about this thread to see if he found any results....
https://honda-tech.com/zerothread?id=1748053
Old Oct 9, 2006 | 03:49 PM
jwyndsdime's Avatar
i forgot to mention, I started an internship at a well known local "racing engines" and machine shop. Im doing all of my boring, cutting the valve seats etc. I am very fortunate to have this oppertunity. thursday I'm going to talk to my boss and start doin measurments on everything, he also has an engine dyno, where I will be doing my tuning
Old Oct 11, 2006 | 05:43 PM
jwyndsdime's Avatar
anymore info?
Old Oct 11, 2006 | 07:42 PM
yOnKiNaToR's Avatar
Default Re: (jwyndsdime)
internship eh? what shop? i'm from montrose, pa and didn't know anything like that was around tunkhannock. let me know on the dyno!
as for using mahles, i hear good and bad. personally, it'd be too much of a chance to take to use stock sleeves. spend the grand and sleeve it and you won't have to worry.
fastdohc
Aug 21, 2010 08:48 PM
justinqualls1
Aug 21, 2009 07:02 PM
crazykid
Jul 25, 2006 04:55 AM
Citystar
Jan 27, 2005 12:59 PM
satan_srv
Oct 24, 2002 09:23 PM
