Broken piston ring?
Old Oct 4, 2004 | 05:27 AM
dominate9's Avatar
Default Broken piston ring?
I busted a balancer shaft bearing in my Prelude. The bearing is right next to the #3 cylinder. When it broke, it took the tip of the oil squirter with it and closed it shut. I have pulled the crank to replace the balancer shaft metal. I inspected the cylinders by pulling the pistons up and down the cylinder by the rods. All the of the pistons are moving up and down smoothly, but the #3 piston is very hard to move and it makes a sucking sound when I try to move it. In fact, I can't puish it all the way towards the head and it springs back when I try. From the bottom of the piston, I don't see any scarring on the cylinder wall. Could I have messed something up or maybe it's like that from the lack of lubricant after the oil squirter broke and just needs some oil? What could be wrong?
Old Oct 4, 2004 | 07:16 AM
LudeyKrus's Avatar
Sounds like you're trying to push the piston up w/ the combustion chamber still sealed.....
Old Oct 4, 2004 | 07:19 AM
dominate9's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you're trying to push the piston up w/ the combustion chamber still sealed.....</TD></TR></TABLE>
My friend said something about trying to push the piston in while the valve stem was down. Is that along the lines of what you are saying?
Old Oct 4, 2004 | 07:20 AM
LudeyKrus's Avatar
Yup; I should have elaborated more.
Is the head off?
If not, pull out the spark plugs so that the air can move out of the cylinders when you push the piston up.
Old Oct 13, 2004 | 06:45 PM
dominate9's Avatar
Yup. That worked. Thanks
Jeanious
Oct 28, 2007 03:44 PM
Topdawgg
Feb 18, 2007 11:31 AM
Sport_Injected
Oct 20, 2004 02:54 PM
dominate9
Oct 3, 2004 11:06 AM
1stGENGSR
Sep 2, 2004 09:46 PM
