Ring gap.. how do i determine what mine should be?
I have a set of Wiseco 81.5mm pistons, with the rings that came with them...
b18a block...
b18a block...
Re: Ring gap.. how do i determine what mine should be? (Topdawgg)
Re: Ring gap.. how do i determine what mine should be? (earl)
thats good for showing the process.... im lookin for the specs for wiseco 81.5mm pistons for boost..
Re: Ring gap.. how do i determine what mine should be? (asubennett)
anyone had to file there oil ring?? this ring doesn't hold it's shape in the cylinder so not sure about the gap but when i sqeeze in on the piston it looks like it overlap. is this rite?? cp piston...
Re: Ring gap.. how do i determine what mine should be? (rocket_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket_R »</TD></TR><TR><TD CLASS="quote">anyone had to file there oil ring?? this ring doesn't hold it's shape in the cylinder so not sure about the gap but when i sqeeze in on the piston it looks like it overlap. is this rite?? cp piston...</TD></TR></TABLE>
I have never have to file the oil rings. They're always right to the specs. If yours overlap, you may have gotten a wrong set, which I have seen that happen.
Re: Ring gap.. how do i determine what mine should be? (Flamenco-T)
The formula for sizing the top and bottom compression rings is bore size (in inches) x 0.006", and then add 0.004 for the secondary compression ring gap.
according to Wiseco's website the multiplier for your top ring is .005", for your second ring it's .0055" and the gap is .0015 for your oil rings.
With my CPs I went with CP's recommendation, their multiplier is higher than wiseco's.
Sport_Injected
10-20-2004 02:54 PM
