Brake light problem!
Hello so i have a problem when i press the brake pedal my brake lights dont light up. but if i turn the switch for my headlights they light up like they usually do. but once again press the brake and nothing. i have tried 2 differnt sets of tailights and its the same thing so idk what to do any ideas? turn signals and reverse lights work also
Should be switch down by the brake pedal that is engaged when you put your foot on the brake. Test it to make sure you are getting an output when you apply the brakes. If not buy a new one and replace it. Have seen them go bad.
