bore a 2.3?
Old Apr 28, 2003 | 04:46 PM
mhgleitz's Avatar
Default bore a 2.3?
anyone know anyone who has bored an H23?
Old Apr 28, 2003 | 05:43 PM
EpDarks's Avatar
Default Re: bore a 2.3? (mhgleitz)
To my understanding a 2.3 liter H-series engine is as big as it gets.
People stroke them to 2.6 liters though... With good results.
Old Apr 28, 2003 | 05:50 PM
optikal_blitz's Avatar
2.6 liters...that is sick. do you have to get high comp. pistons to up the hp w/ that?
Old Apr 28, 2003 | 05:56 PM
noslude93's Avatar
Default Re: (NatakuBlitz)
I bored my H23 20 0ver, So far so good.
You need special stones.
Old Apr 28, 2003 | 07:07 PM
Prelude Vtec 23's Avatar
Default Re: (noslude93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noslude93 &raquo;</TD></TR><TR><TD CLASS="quote">I bored my H23 20 0ver, So far so good.
You need special stones.</TD></TR></TABLE>
20 mm over??????? or do you mean 2.0 mm over.
Old Apr 28, 2003 | 07:15 PM
BoostedH23a1's Avatar
Default Re: (Prelude Vtec 23)
just because u bore it .02 doesnt make it at 2.5 litre...
Old Apr 28, 2003 | 07:23 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Vtec 23 &raquo;</TD></TR><TR><TD CLASS="quote">
20 mm over??????? or do you mean 2.0 mm over.</TD></TR></TABLE>
20 thousands on an inch over
Old Apr 29, 2003 | 09:45 AM
mhgleitz's Avatar
where can i find a stroke kit for the H23?
Old Apr 30, 2003 | 07:25 AM
domslude's Avatar
Default Re: (mhgleitz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhgleitz &raquo;</TD></TR><TR><TD CLASS="quote">where can i find a stroke kit for the H23?</TD></TR></TABLE>
that's what I was wondering.
Old Apr 30, 2003 | 09:10 AM
Greyout's Avatar
Default Re: (domslude)
1mm over is still a 2.3L
2mm over makes it a 2.4L. I did the math a long time ago, if I remember correctly it increases the displacement by 126cc's.
Old Apr 30, 2003 | 06:36 PM
noslude93's Avatar
They come stock with 87 mm, I put in 87.5 mm.
Old Apr 30, 2003 | 06:44 PM
mhgleitz's Avatar
how do you like the results? how did you go about doing it?
Old Apr 30, 2003 | 07:26 PM
ludesleep's Avatar
87?? i thought it was 84?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noslude93 &raquo;</TD></TR><TR><TD CLASS="quote">They come stock with 87 mm, I put in 87.5 mm.</TD></TR></TABLE>
Old Apr 30, 2003 | 07:47 PM
satan_srv's Avatar
Default Re: (ludesleep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">87?? i thought it was 84?</TD></TR></TABLE>
stock bore on an H23 is 87mm, same as H22a.
Old Apr 30, 2003 | 07:49 PM
mhgleitz's Avatar
can you bore by changing sleeves or do you actually bore the sleeve itself?
Cottonwoodz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">stock bore on an H23 is 87mm, same as H22a</TD></TR></TABLE>
Old Apr 30, 2003 | 07:53 PM
ludesleep's Avatar
Default Re: (Cottonwoodz)
well how come my 87mm je pistons would not even come close to fitting in my stock block?
Old Apr 30, 2003 | 07:59 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhgleitz &raquo;</TD></TR><TR><TD CLASS="quote">can you bore by changing sleeves or do you actually bore the sleeve itself? </TD></TR></TABLE>
umm...you can bore and hone the stock sleeve a max of .25 over to 87.25mm
anything above that and you have to resleeve the motor. Sleeves usually will be installed like 30 under 87mm, then the machine shop bores them out to whatever piston size you chose. Max bore on an H series iron sleeve (aftermarket) is 89.5mm, 90 is pushing it.
I am bored to 89mm.
Old Apr 30, 2003 | 08:01 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">well how come my 87mm je pistons would not even come close to fitting in my stock block?</TD></TR></TABLE>
cause they weren't 87mm....
did not not measure the pistons and the block? to see?
And why the hell would you be trying to put forged pistons in a stock block?
Old Apr 30, 2003 | 09:29 PM
ludesleep's Avatar
Default Re: (satan_srv)
the pistons are 87mm ..its stamped on the bottom of the piston
And i was just fawkin comparing them cause my old block that was resleeved looked bigger than my stock block....
Old May 1, 2003 | 09:19 AM
mhgleitz's Avatar
So those of you who have bored above the 87mm, what kind of result did you get across the graph?
Old May 1, 2003 | 06:12 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mhgleitz &raquo;</TD></TR><TR><TD CLASS="quote">So those of you who have bored above the 87mm, what kind of result did you get across the graph?</TD></TR></TABLE>
if you kept compression the same....boring increases hp and torque fairly proportionally...but usually people up the compression at the same time so it's not so cut and dry
Old May 2, 2003 | 05:49 AM
mhgleitz's Avatar
how high would you take the compression if you wanted to be N/A and run on 93 octane?
Old May 2, 2003 | 02:44 PM
user 9782082308's Avatar
I believe Top Fuel of Japan has or had one. Their sites not working for some reason tho.
Depeche
Jun 12, 2007 10:37 PM
jwyndsdime
Oct 17, 2006 08:45 PM
HondaH22A
Sep 29, 2005 10:57 PM
mrxhe1neken
Jan 15, 2005 09:38 AM
shyboy_02
Sep 28, 2003 09:12 PM
