boosting the H22!
Old Apr 24, 2003 | 04:16 PM
NoLipRacen's Avatar
Default boosting the H22!
i have desided to boost my lude however i feel that my H22A1 with 85000 couldnt take it for long... at least for what i plan on doin. so i am planning to buy a JDM H22a with low miles. i am looking to do a custom setup. with a Garret T3/T4E turbo and other various parts. first however will that turbo be able to easily pump out 15-20 pounds? and as for my internal setup i am planning to 9:1 comp pistons but what brand also what kinds of rods/wrist pin/crank/rings/seals/headcgasket should i use? and what should i do head wise? i have not been able to find any turbo cames for the h22a? also what about valve job wise? will a 3 angle be best?
lastly are the aftermarket pistons for the h22a1 the same as the h22a? money is also not much of a concern sinco i dont have to pay for much. sorry for all the questions just wanted to be sure on the setup. Thanks guys
Old Apr 24, 2003 | 04:22 PM
Elkins911's Avatar
Default Re: boosting the H22! (LudeTuner)
how much you want for your stock h22?
Old Apr 24, 2003 | 04:27 PM
NoLipRacen's Avatar
Default Re: boosting the H22! (Elkins911)
i already have a buyer hes paying me 1000 when i take it out and im gunna take his f22. unless you like to top that
Old Apr 24, 2003 | 04:29 PM
Elkins911's Avatar
**** man. ill top that. you doing the work yourself? i would be willing to pay 2k if i can drive out there and swap with you (get the h22 in my car running, and my f22 into your car running).
Old Apr 24, 2003 | 04:34 PM
NoLipRacen's Avatar
naw it wouldnt be for a while bcuz want get the H22a before i sell my a1, but this buyer is one of my friends and he is willing to wait
Old Apr 24, 2003 | 04:50 PM
sslude's Avatar
you turned down a 1000 dollar increase? i wouldnt turn that down if i wre you. you could get some stuff for your turbo iwth that money
Old Apr 24, 2003 | 05:35 PM
NoLipRacen's Avatar
Default Re: boosting the H22! (sslude)
well i dont have it yet and i wont have it for a while im trying to get it all laid out right now
Old Apr 24, 2003 | 05:58 PM
NoLipRacen's Avatar
but what about the build guys?
Old Apr 24, 2003 | 06:05 PM
Ima2nr's Avatar
look at my signature to see some of the mods to build my H22. it makes 415 whp (approx 500 crank hp) on 93 octane as a daily driver.
Old Apr 24, 2003 | 07:15 PM
NoLipRacen's Avatar
Default Re: boosting the H22! (Ima2nr)
what kind of crank? tell me its not a stock h22a crank
Old Apr 24, 2003 | 09:06 PM
PoweredByPrelude's Avatar
Thats alota chrome...damn nice job tho , still not big on the chrome tho
Old Apr 27, 2003 | 04:29 PM
Ima2nr's Avatar
Default Re: boosting the H22! (PoweredByPrelude)
the stock crank is good to approx 1000 hp. no need to replace it. just don't try to turn 2 many RPM. I'm pulling to 8400. I've read that around 9000 rpm the crank experiences harmonic distortion, and will cause it to twist and eventually break. I do have titanium retainers, clips, ect in the valve train for efficentcy purposes.
Old Apr 27, 2003 | 04:52 PM
typeSwarrior's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeTuner &raquo;</TD></TR><TR><TD CLASS="quote">i have desided to boost my lude however i feel that my H22A1 with 85000 couldnt take it for long... at least for what i plan on doin. so i am planning to buy a JDM H22a with low miles. </TD></TR></TABLE>
Why are you looking for a new motor for? Since you plan on replacing ALL of your internals on the JDM H22 that you want, why not just rebuild the one you have and save yourself the time, hassle, and money your gonna spend on a new motor? Just my thoughts on that...
Old Apr 27, 2003 | 05:04 PM
4bidden's Avatar
Default Re: boosting the H22! (typeSwarrior)
I'd love to have a boosted lude running around the Phx area. Let me know if you ever need any help with any of the build or whatever.
Old Apr 30, 2003 | 08:31 PM
mugensport9's Avatar
Default Re: boosting the H22! (4bidden)
thomas i kinda agree with the other guy. they money your going to spend on the jdm motor u could easily spend on fully building the motor u have right now. send it off to get built, get it done right for cheap. i can hook up with a guy for that part. he will build it to your specs for a good price. this way u save money and the hassle. plus my techy will let u know your options on the build and what are the best and worst products. let me know and i will give u his aol and his e-mail so u can start the nagotiations now. call me up and remind me.
-Gus-
Old May 2, 2003 | 04:13 PM
Datum1Tuning
Guest
Posts: n/a
Nice Set-up..What's the cylinder bore size? My project is almost to completion. Can't wait&lt;
Got some prelude part I need to get rid of!
Old May 2, 2003 | 07:31 PM
Ima2nr's Avatar
Default Re: (Datum1Tuning)
the bore is stock (84mm if my memory is correct). that way if I break something, the block can be remachined (bored over) without starting over with another block. If you goto the maximum bore on your first build, then you have nowhwere else to go if you scuff a cylinder wall....
Old May 2, 2003 | 07:39 PM
NoLipRacen's Avatar
Default Re: (Ima2nr)
the only reason i would want to start over with a new engine is because for some reason mine is running slow. and i dont know why. once i get it re-tuned and get a compression test i hope everything will be alrite, and if it isnt than ill get a new one. but i do see what you mean, i know i would save alot of money if i did it your way. im just afraid i will run into problems with my engine (in its current state)
Preludelearner
Mar 21, 2015 10:04 PM
PreluWD
Nov 8, 2007 05:33 AM
tranceguy
Oct 5, 2002 01:11 AM
