battery Question (quickie)
Old Nov 16, 2002 | 05:49 PM
visual's Avatar
Modified by visual at 11:52 PM 1/5/2007
Old Nov 16, 2002 | 06:19 PM
drift's Avatar
New User
Default Re: battery Question (visualvb)
the battery charges while a car is running and the alternator is functioning properly. the cells in your battery have probably just worn out. go buy a new battery
Old Nov 16, 2002 | 08:57 PM
Ludester's Avatar
Diehard IMO
Old Nov 16, 2002 | 10:56 PM
Pdu-Nz's Avatar
Default Re: battery Question (Ludester)
The Battery Light will come on if the Alternator isnt charging. It will not come on if your battery is stuffed so the only way to tell is if you test it or change it. There is no point buying a new battery and it still dosnt charge...
Old Nov 16, 2002 | 11:35 PM
thehondaguru's Avatar
Default Re: battery Question (Pdu-Nz)
yes PDU-Nz is right get your battery checked and then I would go for the altinator and see whats up with that. Do you have a stereo sysyem that requires high voltage? Sorry I'm Drunk.
Old Nov 17, 2002 | 09:37 AM
tonydatyga's Avatar
Default Re: battery Question (95 lude)
Why are you drunk and posting? Don't you have better things/people to do? Anyways, go to sears or something and have them load test your battery. Also check your alternator belt tension as a slipping belt will glaze over time and only give you a fraction of its rated output. You can hear it chirping while trying to charge but you may not hear it due to exhaust+stereo and all the other stuff
Wiretaju
Jun 25, 2010 03:02 PM
hondaracer13
Jul 19, 2007 07:45 PM
ef9one6
Apr 17, 2007 07:31 PM
idewson
Aug 31, 2006 11:45 AM
