Straightpipe or High flow cat????
hey guys, i posted a new thread earlier about my CEL light being on after I took off my catalytic converter and put on a straight pipe. I bought this so called straight pipe for only 15 bucks brand new and it fits my 98 ex fine. It has to holes in it (one with a bolt plugging it, the other to allow for the O2 censor) My question is : if it allows for the O2 censor, wouldn't it be considered a high flow cat.? I am confused, please help. I'm having no other problems with my car except the damn CEL light. If the CEL light is on, I will reset the ecu and it will stay off UNLESS i drive the car above 60 or so for a while, then drive slower speeds like 30 or 40? Is there a way to trick the computer the keep the CEL light off.
thanks
andrew
thanks
andrew
Re: Straightpipe or High flow cat???? (redcivicex2424)
there are o2 eliminators which make the ecu think the o2 is hooked up and sending normal. import parts sells them. having a straight pipe is not like having a high flow converter, the reason u got a cel is cuz the straight pipe doesn't heat up like a cat high flow or not.
Re: Straightpipe or High flow cat???? (sohc_boy)
is your second o2 sensor even hooked up? there are **** loads of people around here with no cats or gutted cats and they never have cel's. some thing else must be wrong!
