ATTS drain plug
Old Oct 12, 2006 | 09:30 AM
Touge Tuning's Avatar
Default ATTS drain plug
Does anyone know the size and thread pitch of the ATTS unit drain plug?
Old Oct 12, 2006 | 09:34 AM
Shakes's Avatar
space cadet
Default Re: ATTS drain plug (Stealth1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth1 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the size and thread pitch of the ATTS unit drain plug?
You should be able to get that info from the dealer. Pretty sure its the same pitch as the tranny / engine oil threads.
Old Oct 12, 2006 | 09:39 AM
Default Re: ATTS drain plug (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">You should be able to get that info from the dealer. Pretty sure its the same pitch as the tranny / engine oil threads. </TD></TR></TABLE>
I looked on SLhonda and this is the image I came up with.
either #22 is the trans drain plug or the ATTS drain plug and #33 is a drain plug aswell.
Old Oct 12, 2006 | 09:42 AM
Revi's Avatar
#22 is the ATTS drain plug and #33 is where you fill it up at.
Old Oct 12, 2006 | 11:50 AM
Default Re: ATTS drain plug (Revi-Ra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra &raquo;</TD></TR><TR><TD CLASS="quote">#22 is the ATTS drain plug and #33 is where you fill it up at.</TD></TR></TABLE>
thanks for the clarification, in the list sheet it says #22 is bolt plug and #33 is drain plug.
Old Oct 12, 2006 | 01:55 PM
Revi's Avatar
The list sheet is smokin crack! Ive changed the ATTS oil a million times. Think about it, how is 33 going to be the drain plug when its the highest bolt on there?
Trust me my friend, drain on 22 fill on 33. 1qt of ATF.
VtecAdvantage
Mar 30, 2010 10:10 PM
macson
Nov 7, 2008 11:09 AM
BodyKits NW
Feb 19, 2004 01:57 PM
SimbaDogg
Dec 21, 2003 06:25 AM
King Tut33
May 14, 2003 04:31 PM
