Apex'i ITC
Old Feb 14, 2003 | 12:45 PM
Memo6453's Avatar
Default Apex'i ITC ?
I have 2001 Base Prelude which is OBD II and someone told me that if u buy the ITC its a waste of money on OBD II because you cant tune it as precise as OBD I is this true? And WOuld an ITC work go0d with my V-AFC because my friend has one right now to sell to me and i was thinking about getting it, but only if it will help!
[Modified by Memo6453, 9:51 PM 2/14/2003]
Old Feb 14, 2003 | 01:05 PM
Memo6453's Avatar
Default Re: Apex'i ITC ? (Memo6453)
anyone kn0w about this???
Old Feb 14, 2003 | 01:07 PM
Boostless97Lude
Guest
Posts: n/a
dude, the post didn't even make it 1/3 of the way down, and you already bumped it..... have some patience
Old Feb 14, 2003 | 02:41 PM
sslude's Avatar
Default Re: Apex'i ITC ? (Boosted97Lude)
hahaha, newbs. have some patience my young grasshopper
Old Feb 14, 2003 | 03:29 PM
Memo6453's Avatar
what do u mean i bumped it? and i posted it earlier today and i just checked back on it now so what you talking about? its a simple question if u didnt want to answer it then dont...dont got to post something dumb about it...im asking for help not your opinion. and still waiting if anyone out there knows about this . thanx
Old Feb 14, 2003 | 04:14 PM
Boostless97Lude
Guest
Posts: n/a
yeah, you posted it, and then asked "anyone?" just a couple hours later.... in case you haven't noticed, the Prelude forum isn't the most active forum on H-T. if someone knew, they would have answered it by then, you didn't have to ask again before the topic even made it 1/4 of the way down the Forum page........
and "bump" refers to when you reply to your own post just to get it back to the top of the Forum page, typically people don't bumpo a topic until it is at least to the second page
and, to answer your question, i say it's complete BS, it shoudn;t make any difference wether you car is OBDII or OBDI, it all works off the same principles
Old Feb 14, 2003 | 05:26 PM
Memo6453's Avatar
i understand but do u think its worth $300 or it doesnt do that much of an increase in hp/torque. Would u buy one?
Old Feb 14, 2003 | 05:37 PM
Boostless97Lude
Guest
Posts: n/a
i'm actually not too sure about the ITC, i am not really all that familiar with it, but i do know that the V-AFC will make a difference if properly tuned, so i would assume that the ITC would be similar
Old Feb 14, 2003 | 09:11 PM
Memo6453's Avatar
Do you think that getting the Type-S pistons would be a difference?Like would i be quicker or is there more to it than just pistons to get a little more power...cause i can get the pistons for like $360 and i wouldnt mind spending that if its an increase that is visible! know of any go0d websites?
Old Feb 14, 2003 | 09:27 PM
Cottonwoodz's Avatar
SUPER ITC (Ignition Timing Converter)
Ignition Timing controller that allows the user to modify ignition timing from inside the vehicle.
The Super ITC allows the user to modify the crank angle signal and adjust the ignition timing of the vehicle. Ignition Timing can be modified + / 15%. By using the Super ITC in conjunction with the Super AFC fuel controller, a new level of performance and flexibility can be attained which was never before possible with entry-level sub computers.
The ITC allows the user to modify ignition timing according to RPM specific levels, much like the Super AFC modifies fuel. The five ***** on the face of the unit indicate a particular RPM level at which timing may be modified.
Cut and paste
Old Feb 15, 2003 | 08:27 AM
Memo6453's Avatar
Default Re: Apex'i ITC ? (Cottonwoodz)
works for me...thanx man i think i might be getting it...
Old Feb 15, 2003 | 08:29 AM
Boostless97Lude
Guest
Posts: n/a
just curoius, why do you need to control your timing?
Old Feb 15, 2003 | 08:47 AM
Memo6453's Avatar
i dont exactly know how it works but my friend says its a go0d combination with the V-AFC and that it could make a difference in your car performance so i wanted to get that and the type-s pistons to make my car a little faster for now so so so much $$$...get me?
Old Feb 15, 2003 | 08:50 AM
Boostless97Lude
Guest
Posts: n/a
if i were getting something to alter my ignition timing, i would get an MSD SCI ignition with the BTM or a Crane Cams HI-6 igntion. they both have adjustable igntion timing, plus you get the more powerful spark
DirtyLude's Avatar
It will work on the 5th Gen. It modifies the crank trigger signal.
It is absolutely not worth $300.00. You're not going to get much out of it.
Old Feb 15, 2003 | 03:53 PM
Memo6453's Avatar
Default Re: Apex'i ITC ? (DirtyLude)
my friend is selling it for $270 to me, would u grab it or no...i mean they dont make them anymore so i thought it was a steal. what you think?
Old Feb 15, 2003 | 04:07 PM
DsITR's Avatar
Why are you trying to alter your timing??
W/type S pistons...like you stated above, there won't be a need to retard your timing...unless you run shitty gas.. (I would run 91oct minimum.)
You could advance your timing...but that is definatley not worth 300 bucks.
Old Feb 16, 2003 | 07:35 AM
Memo6453's Avatar
Default Re: Apex'i ITC ? (dsludefosho)
ye i do run the go0d gas and i am getting the type-s pistons...u say its dumb to get the ITC...damn, i thought it wouldnt hurt. not even for $270 u still think its a waste? what else would u get to go along with the pitons for a nice upgrade for less than $400.
Old Feb 16, 2003 | 07:38 AM
Boostless97Lude
Guest
Posts: n/a
i say it's a waste, if you spend that much, by a high output ignition with a timing control
Old Feb 16, 2003 | 01:47 PM
Memo6453's Avatar
which is how much and what is that an MSD? give me specifics im new to this...
boostedhb
Jun 29, 2007 10:05 PM
civic4dr
Apr 26, 2004 10:51 AM
iam7head
Mar 8, 2003 10:43 PM
