Anyone had this problem?
Old Jan 12, 2003 | 08:43 PM
CHK4TIX's Avatar
Default Anyone had this problem?
Ok, i was trying to take my new swap out for a spin but before i did i was going to install my new greddy header. So i tried driving it up on some ramps so i could get my jack under the car. When i did this the car made a loud noise and now i dont have any power getting to the wheels. I have taken off the tranny and replaced the clutch. But before i put it back together i was woundering an easy way to check the diferential to make sure its not the problem.
If any one has any suggestions, that would be great.
Thanks
Old Jan 13, 2003 | 12:32 AM
CHK4TIX's Avatar
Default Re: Anyone had this problem? (CHK4TIX)
anyone?
Old Jan 13, 2003 | 06:07 AM
3gdude's Avatar
Well, sounds to me like your axle may have popped out of the transaxle when you ramped it. If the axle on the passenger side came out of the trans far enough to not be engaged inside differential then the car will not move. Thats the only thing I can think of that would cause this. Seems like you would have noticed this when you did clutch. If its a motor swap set-up, your axle may be a bit short....3gdude
Old Jan 13, 2003 | 06:38 AM
2point6's Avatar
Default Re: Anyone had this problem? (3gdude)
Old Jan 13, 2003 | 12:09 PM
Shakes's Avatar
space cadet
Default Re: Anyone had this problem? (2point6)
half shaft. if thats not it which it probably is, then it may be the pilot bearing.
Old Jan 13, 2003 | 05:46 PM
CHK4TIX's Avatar
Default Re: Anyone had this problem? (shakes)
Thanks for all the input
I will be checking out everything in the morning. I will let you guys know what i find
Ferio4ya
Nov 25, 2009 10:57 AM
slo_ej8
May 16, 2008 06:45 PM
tuan...
Aug 27, 2004 05:03 PM
Layziebtnh055
Jun 14, 2004 10:52 AM
white95eg
May 20, 2004 06:10 AM
