alternator ?
belt might be shot
but you loosen the 12mm nut underneath the alternator on the right side, loosen the 14mm bolt that runs through the alternator on the top, and then you tighten or loosen the 10mm tensioner bolt until you get desired belt tension
its pretty simple, but make sure your belts good
Fo-Do Fanatic
Apr 7, 2010 03:59 AM
B2FiNiTY
14
Sep 24, 2003 01:17 PM
