Alternator problem
Old Oct 17, 2003 | 08:06 AM
Rival23's Avatar
Default Alternator problem
Does anyone know if the only spot to tension the alternator is the bolt on the top, I just replaced my belt, and it is the exact same size as the last one, but i cant get it tight, i adjust the bolt on the top all the way out but it still doesnt tighten the belt enough
Old Oct 17, 2003 | 10:28 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Alternator problem (Rival23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rival23 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if the only spot to tension the alternator is the bolt on the top, I just replaced my belt, and it is the exact same size as the last one, but i cant get it tight, i adjust the bolt on the top all the way out but it still doesnt tighten the belt enough</TD></TR></TABLE>
Are you prying out on the alternator itself to tension the belt? You have to put something between the alternator and the bracket like a prybar and push out on the actual alternator itself to get it tight.
CHANCELLOR12
Oct 2, 2015 01:55 AM
nemesiskrp
Apr 14, 2009 10:10 PM
Civiclx
Jun 10, 2007 03:47 PM
MechEng
May 7, 2006 01:29 PM
B2FiNiTY
14
Sep 24, 2003 01:17 PM
