almost crashed, need help fixing my problem
Old Jan 19, 2003 | 06:06 PM
sagaprelude's Avatar
Default almost crashed, need help fixing my problem
well, i got on the freeway, switch lanes, then hear a loud noise, then i start to fight with the wheel, so i pull over thinkin its a flat.
i noticed tho, that when i braked, it was really rough. checked the tire, it was fine, yet, wasnt able to drive, wheel wouldnt move.... so i got the car towed home.
i take off the wheel, heres what i see....
new AGXs and my new rotors..
look around, and find the problem, these 2 bolts were off
basically, my wheel was just spinning freely with no souce of control.
the problem, i bought the bolts to replace those that were missing, but im havin a really hard time gettin the holes to line up to fit the bolts. any suggestions or advice would be greatly appreciated, thanx!
Old Jan 19, 2003 | 06:11 PM
RotiEatter's Avatar
Ditto
Default Re: almost crashed, need help fixing my problem (sagaprelude)
Wow, that sucks....good thing nothing bad arouse from it...
Self-locking nut? I would suggest that. Worth a shot atleast.
Old Jan 19, 2003 | 06:15 PM
Honda318dx's Avatar
Default Re: almost crashed, need help fixing my problem (RotiEatter)
They are just bolts that go into the control arm from the trailing arm.. they can be a MAJOR PITA to get in sometimes.. Just do a lot of prying w/ prybars to get everything to move around and lined up..
Old Jan 19, 2003 | 06:57 PM
BoostedH23a1's Avatar
Default Re: almost crashed, need help fixing my problem (Honda318dx)
doesnt that controll the caster? been a while since ive been into my suspension but it if its u can remove the other side... just remember how many shims u have on each side so u can get your caster correct again.. might wanna have it realigned too.. if the bolts came out it might have messed up the treads if it did i would get a helicoil kit..
scottmog
Jul 19, 2009 01:47 PM
JDMSol626
Jul 16, 2005 01:54 AM
reza"
21
May 15, 2005 01:04 PM
jagged4698
Mar 20, 2004 03:56 PM
nargenar
Jun 7, 2002 07:26 PM
