ABS lights on??
Today when i started my car everything went normal and then a few feet down the road the ABS light came on? i turned my car off and restarted it and it stays off untill i disengage the clutch then it stays on all the time. what could be the problem a fuse maybe or the whole damn ABS stuff and Can I just leave it and not have ABS? thanks
Mine also does the same. The ABS light does not come on whenever I start the car. I have to move forward a few feet before it clicks on. I still to this date don't know what it is. I don't think its throwing a code but I'll check again tomorrow.
I have a similar problem , the ABS light is always on , its been on for 1 year now and even my mechanic dose not seem to know what the problem is. They think it can be the abs sensor but so far nothing. Now for the strange part , normaly i have no ABS and i have been driving around with out ABS. This winter we got a **** load of snow here in toronto so i went out driving around type of rally stile and the ABS system kicked in , i felt the pedal kicking back during braking. I had ABS for a few days till it died again ...... Still have no fix
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synerain »</TD></TR><TR><TD CLASS="quote">Mine also does the same. The ABS light does not come on whenever I start the car. I have to move forward a few feet before it clicks on. I still to this date don't know what it is. I don't think its throwing a code but I'll check again tomorrow.</TD></TR></TABLE>
same here...is it the same connector as the cel or is it the one right next to it? I've got a 96 4th gen SI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">My **** did that, and stayed on, so I just took the bulb out...</TD></TR></TABLE>
ok..... that's a way to hande it.... a very bad way.....
anyhoo, my car started doing the same. damn, i guess this is common with 4th gen preludes...
same thing, i start the car and move a bit and it comes on. and it stays on. my ABS doesn't work.
speed snesor???
speed snesor???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude_2_NV »</TD></TR><TR><TD CLASS="quote">My car did that a few weeks ago. I checked the speed sensors and one of the screws on the bracket came loose. I tightened it and it was all good.</TD></TR></TABLE>
i'm gonna check mine soon.... i hope it's the same thing.
1baddturbosi
Jun 6, 2008 05:23 AM
