Abs light is on! help
Old Feb 17, 2005 | 05:11 PM
RA61825's Avatar
Default Abs light is on! help
i have a 95 prelude si what does it mean when the abs light goes on?
-thnx
Old Feb 17, 2005 | 05:46 PM
mafia's Avatar
Default Re: Abs light is on! help (RACERX72)
I have the same problem, but on mine the back left wires are dissconcted, to lazzy to fix it.
Old Feb 17, 2005 | 05:52 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACERX72 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 95 prelude si what does it mean when the abs light goes on?
-thnx </TD></TR></TABLE>
The abs light goes on when your abs sensors either aren't reading correctly or are completely bad. I would check your sensors to find any frayed wires or anything. They run along the crossmembers. Good luck!
Old Feb 18, 2005 | 05:46 AM
kulrevon's Avatar
Default Re: Abs light is on! help (maxvtec7500)
or we could do a search for abs codes and will find TA DA!
answers
https://honda-tech.com/zerothread?id=978933
Old Feb 18, 2005 | 05:49 AM
thelarkascend1ng's Avatar
it's usually always a sensor. i just took it to a shop. they had it done in like a day. it's not a big deal.
Old Feb 18, 2005 | 12:57 PM
Showtime_III's Avatar
Default Re: (thelarkascend1ng)
how much did it cost to get your abs fixed
Old Feb 18, 2005 | 01:04 PM
kulrevon's Avatar
Default Re: (Showtime_III)
or we could check the codes find out whats wrong ourselves and save 70 bucks an hour labor. what if showtimes abs problem is completely different then thelarkascend1ng. what does the cost matter if your problem is completely different.
Old Feb 18, 2005 | 05:19 PM
Default Re: (kulrevon)
check what codes and how?
Old Feb 19, 2005 | 02:25 PM
teamlegacy's Avatar
ign on. jumper wire to the dummy service connector. count the blinks. long blink = 1st number, short blinks = second number.
i had code 1 on my h22a cb7 accord. bad pump, so i said **** it and completely disabled ABS.
Old Feb 19, 2005 | 03:01 PM
yeah, it's not really a technical answer i know, sorry.
most of the time though, in my experience and friend's, it's a sensor. getting a code = more power to you. , for that at least, i didn't do it on my own.
prelude2.2
Aug 27, 2012 12:21 AM
jp1racer
Dec 22, 2010 08:12 AM
94integrasc
Jun 27, 2006 07:12 PM
Lost Type R
Mar 22, 2003 07:32 PM
