abs light on help!
Old Aug 22, 2012 | 12:37 AM
prelude2.2's Avatar
Icon3 abs light on help!
My abs light is on my 95 ex accord is there a way to find d out why ?
Old Aug 22, 2012 | 09:40 AM
prelude2.2's Avatar
Default Re: abs light on help!
**Bump**
Old Aug 22, 2012 | 10:07 AM
doctorbee's Avatar
Abs light means that you're driving without ABS because something is wrong with it
Old Aug 22, 2012 | 01:16 PM
Bird333's Avatar
You should be able to short the SCS connector and count ABS light flashes.
Old Aug 22, 2012 | 02:21 PM
TalonIV's Avatar
Being a 95 I assume it is OBD2. If you you may be able to gather codes with the right scan tool, unless Honda has a separate way of diagnostics.
Old Aug 23, 2012 | 12:28 PM
badcb7's Avatar
When you start it up is it there? or does it show up after traveling above 7mph. If it only shows up after you driven a little then its most likely a wheel speed sensor.
Old Aug 23, 2012 | 01:19 PM
extralargenog's Avatar
95 is obd1 dude
Old Aug 26, 2012 | 11:51 PM
94AccordSasha's Avatar
hey mine does it after a couple minutes of the car running and it will come on even if im just sitting in one spot any advice on that?
Old Aug 27, 2012 | 12:21 AM
GhostAccord's Avatar
If you use the self diagnostics procedure you can read the ABS codes yourself. With the SCS connector shorted the ABS light will flash the DTcodes that are stored on the ECU.
hondacivic94exvtec
Jul 9, 2007 09:39 AM
LS1powered
Apr 27, 2006 09:13 PM
Shaun92lude
Dec 8, 2004 07:11 AM
vain
Oct 16, 2003 03:26 AM
