ABS LIGHT!!!!!
Old Nov 2, 2004 | 06:27 PM
Steezn4NOReason's Avatar
Default ABS LIGHT!!!!!
I drive a 95LS and My DAMN ABS light will not turn off...is there any way i can reset it or disconntect the damn thing.... Let me know if youve had this problem too... THanks......
Old Nov 2, 2004 | 06:40 PM
timmy8151's Avatar
Default Re: ABS LIGHT!!!!! (Steezn4NOReason)
Scroll down towards the bottom of the thread:
https://honda-tech.com/zerothread?id=978933
Plus if you did a search for "ABS" you would have seen that there are a lot of threads about this problem.
Old Nov 2, 2004 | 08:31 PM
Oleg's Avatar
get the scan tool and check for codes......se what you got and go from there.
(ABS sucks)
Old Nov 2, 2004 | 09:14 PM
timmy8151's Avatar
Default Re: ABS LIGHT!!!!! (Oleg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oleg &raquo;</TD></TR><TR><TD CLASS="quote">get the scan tool and check for codes......se what you got and go from there.
(ABS sucks)</TD></TR></TABLE>
No need for a scanner, a paperclip will suffice.
Old Nov 2, 2004 | 10:18 PM
yeegsr's Avatar
Default Re: ABS LIGHT!!!!! (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">No need for a scanner, a paperclip will suffice.</TD></TR></TABLE>
and how axactly can i do this with paperclip...?
Old Nov 3, 2004 | 12:35 AM
trellix78's Avatar
New User
Default Re: ABS LIGHT!!!!! (yeegsr)
You short the little plug by the ECU (passenger side kick panel), turn the key to
ignition (don't start the car) and watch for the light to flash on the instrument panel.
Long blinks=10's digit, short blinks=1's digit.
If my car wasn't taken apart right now, I'd take pictures.
ABS is broken on my Integra, too. Good luck.
Old Nov 3, 2004 | 04:23 AM
JimBlake's Avatar
Default Re: ABS LIGHT!!!!! (trellix78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trellix78 &raquo;</TD></TR><TR><TD CLASS="quote">Long blinks=10's digit, short blinks=1's digit...</TD></TR></TABLE>NO, NOT for ABS... Look at the sticky thread about ECU & ABS codes. You jumper the same wire, but for ABS codes the syntax of blinks is different. First long blink isn't part of the code. Then they're all short blinks with either short or long space between.
Old Nov 3, 2004 | 04:35 AM
bdkrma's Avatar
Mine's been on for 160000 miles, I dont even notice it anymore
Old Nov 3, 2004 | 06:38 AM
trellix78's Avatar
New User
Default Re: ABS LIGHT!!!!! (bdkrma)
JimBlake is right.
I was trying to go from memory without looking at the Helm manual.
It is different from other ECU codes.
Old Nov 3, 2004 | 09:22 AM
WRTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdkrma &raquo;</TD></TR><TR><TD CLASS="quote">Mine's been on for 160000 miles, I dont even notice it anymore</TD></TR></TABLE>
same here i can't stand abs
eilros
Oct 30, 2007 05:14 PM
Boosted00GSR
Jan 22, 2006 06:18 AM
ghostmill
Oct 27, 2005 11:16 AM
FatBoy4door
Oct 7, 2004 10:21 PM
metal-x
Jan 27, 2004 10:01 AM
