98 prelude p1382 wont start after swap please help
Old May 29, 2012 | 08:18 AM
SmoothCTR's Avatar
Icon6 98 prelude p1382 wont start after swap please help
just change my engine and it only crank but wont start replace the crank sensor because i saw it was touching the pulley i try different distributor different coil, i got spark, i can smell the fuel when i crank. the code say cylinder position no signal, i re check my wires idk what to do next please give me some advise thank you.
Old May 30, 2012 | 07:28 AM
SmoothCTR's Avatar
Default Re: 98 prelude p1382 wont start after swap please help
Ok, so I noticed there was a bent pin in the harness and fixed it. Now I don't have a cel. But the car still crank no start. I have spark, I have fuel, I have compression. Starter works cause it cranks, charging system is good, immobilized key light up and goes away like it should. I'm stumped! Anyone have any ideas?
Does anyone know if the car will start with an obd2 p72 ecu? Reason I ask is because at this point I'm thinking it could be the ecu that's faulty, and I have a p72 that isn't starting it either.
H22LAKERSFAN
Apr 16, 2016 09:21 PM
mynameizstitch
Mar 17, 2012 10:55 AM
hollowman8904
Jan 7, 2009 08:59 PM
97preludetypeblk
Aug 13, 2006 07:27 PM
sounique
Apr 16, 2003 04:23 PM
