92 Prelude... Electrical Problems?
Old May 20, 2016 | 02:50 PM
Z99doc's Avatar
Default 92 Prelude... Electrical Problems?
I hopped in my car the other morning before taking it to get inspected, and im testing everything before i get there. I go to hit the horn and nothing... so i do a little looking and i see the relay on top of the fuse box for the horn isnt working. im familiar with this area of the car as well cause the relay that runs from the ignition to the starter also stopped working... and i just made jumper wires for it. But sadly i cant do that for the horn cause if you try to jump it it beeps. i dont understand the problem i was talking to someone today and they said a grounding issue but i cant find a ground it would lead to. IM LOST SOMEONE PLEASE HELP ME!!!!
Old May 28, 2016 | 12:00 PM
fcm's Avatar
fcm
Old Fart
Default Re: 92 Prelude... Electrical Problems?
The ground to the relay is supplied by the horn button, find the blue/red lead at steering column harness and supply a ground directly to it, if horn works the problem is at the horn buttons or connections to them.
Also the horn relay socket should have two pins that have 12V+ power, if you jumped and the horn worked then at least one of the powers is working, check for the other. 94
Old Jun 4, 2016 | 05:36 AM
Z99doc's Avatar
This is very true! the blue and red wire goes from the back of the relay up to a yellow SRS plug and after tracking which gray wire it is it leads up to the SRS plug right under the steering wheel and it is exactly what fcm said it is the steering column is the poit of where it grounds. Sadly no one knew what the solution was so i had to do all the wire tracking myself lol then a week later i saw fcm posted on this thank you annyways fcm!
Old Jun 4, 2016 | 08:29 AM
snobordboy's Avatar
Moderator
Just a side note, it would be a very good idea to replace bad relays, as opposed to using jumpers in there. Testing via jumpers is an ok idea, but long term there is the possibility of excess voltage draw, or much worse such as overheating components or starting a fire.
If they are tough to find new ones, junkyard cars a great source, and cheap!
Old Jun 14, 2016 | 09:53 PM
P-Motorsports's Avatar
VERY TRUE!
WE MUST NOT FORGET 92 WAS FIRST OF YEAR OF NEW GENERATION
MOST CARS EVEN THESE DAYS (2016) MOST ALWAYS HAVE SOME
SMALL OR EVEN MAJOR ISSUES WITH FIRST COUPLE YEARS
OF PRODUCING A NEW BODY AND ENGINE VEHICLES
RELAYS AND WIRING ESPECIALLY IN 20+ YEARS OLD CARS
TEND TO HAVE REACHED THERE SERVICE LIFE OR NEAR IT
GOOD TO INSPECT UPON WEIRD SYMPTOMS SO
CAN PREVENT A EXPENSIVE/EMBARRASSING TOW TRUCK RIDE
AND ELECTRICAL GROUNDS!!!!
ELECTRICAL GROUNDS IN MY EXPERIENCE HAVE BEEN
MAYBE 50-70% OF MOST ELECTRICAL ISSUES IVE SEEN
WE MUST NOT FORGET MOTHER NATURES BEAUTIFUL CREATIONS
WATER, RUST, RATS, BIRDS, AND JENKY MECHANICS OF ALL
THINGS ARE PART OF LIFE AND ARE SOMETIMES INEVITABLE
BUT MOST IMPORTANT RELAYS ARE NOT WATERPROOF!
WHEN YOU SEE MORNING DEW ON YOUR CAR IN THE MORNING
MAYBE 0.01% OF THAT DEW HAS A 7.2% OF FORMING SOMEWHERE
INSIDE YOUR PRIZE TROPHY WIFE
FRICTION FROM FACTS U GET THE POINT...
THAT NASTY LOOKING *CUMSHOT* GUNK WHEN YOU TAKE A RELAY
OUT OF YOUR FUSE BOX FOR THE FIRST TIME
WAS PUT THERE FOR A REASON!
TO PROTECT YOUR VITAL ELECTRICAL ORGANS FROM
TO MUCH ABUSE ( ALCOHOL AND BAD HABITS)
IS SPECIAL COMPOUND TO PROLONG THE INEVITABLE EFFECTS
OF CONSTANT MOISTURE AND HEAT SOAKING OF THE ENGINE BAY
WELL AGAIN SHORT STORY LONG...
CROSS REFERENCE PART NUMBERS AND WIRING DIAGRAMS
TO ENSURE THE NEW RELAY YOU INSTALL IS
AN ADEQUATE SOLUTION TO YOUR CURRENT ISSUES.
THANKS FOR READING (TO THOSE WHO DID)
ANY INPUT OR CORRECTIONS OF MY RANTING ABOVE
WOULD BE GREATLY APPRECIATED!
Old Jun 16, 2016 | 01:57 PM
fcm's Avatar
fcm
Old Fart
The "GUNK" is di-electric grease. 94
wooddsam
Jan 23, 2011 01:21 PM
rockrogue
10
Sep 15, 2010 08:43 PM
tei344
Nov 9, 2007 05:51 AM
oldbeefcake
13
Feb 24, 2004 08:34 PM
upgraded
Nov 16, 2003 02:59 PM
