Ignition Problem?
Old Jul 10, 2009 | 04:33 PM
skazoo's Avatar
Default Ignition Problem?
I have a 94 Ls with a 2000 Ls motor that has been running fine since the swap (about 40k miles, and two years). I drove 6 hours today from Mississippi to Georgia and the car drove great the whole way.
About two hours after going home I tried to go get some food and the car wont start. All of the accessory lights inside the car turn on and the radio works. When I turn the key to the start position the radio cuts off but aside from that nothing happens. No clicking, no cranking....any ideas?
Thanks in advance.
Old Jul 10, 2009 | 05:25 PM
ek-g6's Avatar
Default Re: Ignition Problem?
Check main relay, and fuses.
Old Jul 10, 2009 | 05:39 PM
skazoo's Avatar
Ive checked the fuses. How do I check the main relay? I thought about just trying to jumper the starter...I really think it is just something wrong with the ignition switch or the relay/wiring.
Old Jul 10, 2009 | 05:45 PM
stevenDAtegra's Avatar
http://www.tegger.com/hondafaq/mainr...ing/index.html
your radio stayed on while starting but now shuts off while trying to start you say?
Old Jul 10, 2009 | 05:51 PM
ek-g6's Avatar
When there is no clicking usually its the main relay. heres a link on how to test.
http://autorepair.about.com/od/engin...nrelay_tst.htm
Main relay is located under dash at the driverside kick panel, it should be gray or black with about 6-8wires (cant remember) going into it.
Old Jul 10, 2009 | 05:52 PM
skazoo's Avatar
If I turn the key to the on position everything comes on including the radio. When I turn it further to the start position the radio is no longer powered, its not a factory radio but I believe it has always done this. Thanks for the relay link, to be honest I do not even know where it is. I may have to try to get a haynes manual for it.
Old Jul 11, 2009 | 12:09 PM
skazoo's Avatar
bump for day crew
D7KWagon
Aug 28, 2014 12:20 PM
JusAccord
Mar 29, 2012 06:38 PM
FliPCRuSH022
Jul 14, 2009 05:21 PM
Tad
May 22, 2006 12:24 PM
