91 Prelude with brake problems
Old Jun 23, 2001 | 08:27 PM
clockworks's Avatar
Default Re: 91 Prelude with brake problems (jbreak)
Are those floating pins greased enough? That happened on one of my rears, the pin was bone dry and the thing seized and killed my rotor. Other than that, I'd say rebuild the caliper.
Greg
Old Jun 24, 2001 | 08:02 AM
Jarrad_r6's Avatar
New User
I would agree with Greg. Rebuild the caliper piston. It sounds like it is not moving freely under pressure. Although the slider pin needs to be well lubed in this case I doubt that it is the problem. I would rebuild the piston and flush the lines well. It you find debris in the lines then I would do the rest of the lines. You don't want to screw around with brakes not working.
J
crex23
Dec 9, 2011 05:03 PM
silentone
Jun 19, 2009 02:32 PM
117
Jun 22, 2007 08:56 PM
blackEF
Jun 7, 2002 08:50 PM
