Brake problem
Old Jun 18, 2009 | 09:57 PM
silentone's Avatar
Default Brake problem
For reference I have a DA with stock everything.
For some reason, the front driver side caliper doesn't want to decompress leaving me with a caliper stuck on and the wheel not being able to move. I also flushed all the other calipers except for that side because fluid did not want to flush through, so I just replaced it and its fine with that now. But still the caliper gets stuck. Anyone have any ideas on what it could be?
Old Jun 19, 2009 | 12:42 AM
dntnedvtec's Avatar
Default Re: Brake problem
You replaced the caliper? Is it happening to you when you drive? Or when you are parked??? Your piston in your caliper maybe have junk in or around the edges causing it to seize?...(I don't know)
Old Jun 19, 2009 | 02:33 AM
silentone's Avatar
ive already replaced it in the last 24 hours. it happens both when i drive and when im parked, only on the front driver side.
Old Jun 19, 2009 | 04:34 AM
Dogginator's Avatar
Daisy... Daisy...
If you open the bleeder on that caliper, does it release?
Old Jun 19, 2009 | 10:16 AM
safedriver's Avatar
Replace the brake line at that caliper.
The brake line may have an internal collapse. You will be able to send the fliud towards the caliper, when you are bleeding (because, at the brake pedal you have good leverage), but the caliper doesn't have much leverage to force the fluid past a collapse in the brake line (towards the master cylinder), so it does not release.
Old Jun 19, 2009 | 02:32 PM
silentone's Avatar
yes it does now with the new caliper.
thanks, ill get a new brake line from my work and see what happens after that.
96Formula6spd
Aug 25, 2011 05:39 PM
Nighthawk7thGen
Honda Civic (2001 - 2005)
Jul 3, 2008 09:11 PM
LowSlow93Sol
May 24, 2006 07:36 AM
nitroice40
Mar 5, 2004 12:45 PM
blackEF
Jun 7, 2002 08:50 PM
