2001 Prelude Idle Problems
Old Jun 9, 2008 | 09:47 PM
DevotedHond@730's Avatar
Default 2001 Prelude Idle Problems
Hey don't know if this has been posted before...but I just recently purchased a 2001 Prelude(Non-SH) and the only problem is that the Idle bounces up and down when still. After a while, the car idles around 1.5rpm and the car is really jerky when driving. Anyone have any suggestions or any help for a new prelude owner?
Old Jun 10, 2008 | 02:12 AM
KrayzieJ's Avatar
Default Re: 2001 Prelude Idle Problems (DevotedHond@730)
you could check to make sure all the hoses, vacuum lines, etc are connected
Old Jun 10, 2008 | 03:54 AM
LukieLuc's Avatar
Default Re: 2001 Prelude Idle Problems (KrayzieJ)
[QUOTE=KrayzieJ]you could check to make sure all the hoses, vacuum lines, etc are connected[/QUOTE
Then clean your IACV and see what happens after that. Make sure the coolant hoses that go to and come from the idle air control valve are both free from gunk
Old Jun 14, 2008 | 09:24 PM
Hey I unplugged my IACV and the high idle went away but then it still idled between 1200-1600 rpm...felt no vacuum leaks but will try to drain and refill coolant tomorrow. will keep you posted...thanks
Old Jun 14, 2008 | 09:32 PM
Saosinx's Avatar
Default Re: (DevotedHond@730)
https://honda-tech.com/zerothread?id=1979500
Old Jul 4, 2008 | 11:30 PM
Hey quick update...it turned out to be ITM gasket leak. And rough idle was due to channel in ITM for EGR being full of carbon deposits. So cleaned out really good with carb cleaner. After all said and done, car runs smooth.
Inextricabledrvr
Feb 7, 2012 08:31 AM
SD_BB2
Sep 16, 2010 09:53 AM
TheOdd001
Jul 7, 2008 07:32 AM
96hatch87
Aug 25, 2007 03:06 PM
h22831
Jul 18, 2005 06:36 PM
