2.0undersized pistons
i have an 89 b20a5 and i am trying to get 400 hp out of it.i am at the start of the prossess.my main concern when i get my cylinders sleeved where am i going to find some pistons and rods that will fit my sleeves.and is it posible to get that much out of a b20a5
unuther concern is will i bee able to get any uver sized vales or do i really need that
thank you
thank you
i am getting the head ported polished i want to put about 20 bl boost new intake new clutch under drive gears and mabe a little nitro and a few small things what ever i need to get the 400whp i can find everything i need except pistons and rod ot go with my sleeved pistons i am not getting it bored so it will have to bee smaller pistins
is there any place i can get them or get them custom made
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spiderman4532 »</TD></TR><TR><TD CLASS="quote">i am getting the head ported polished i want to put about 20 bl boost new intake new clutch under drive gears and mabe a little nitro and a few small things what ever i need to get the 400whp i can find everything <U>i need except pistons and rod ot go with my sleeved piston</U>s i am not getting it bored so it will have to bee smaller pistins
is there any place i can get them or get them custom made</TD></TR></TABLE>
Your totally lost 20 lbs of boost you mean. And a new intake? I sure hope your talking about intake manifold. You do not sleeve pistons. You have the block sleeved. Do months no years of research before purchasing anything
i know that you sleeve the block cylinders i am wanting 8-1 or 8-1/2 compression ratio just trying to find pistons and rods the right size from not boring block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spiderman4532 »</TD></TR><TR><TD CLASS="quote">i know that you sleeve the block cylinders i am wanting 8-1 or 8-1/2 compression ratio just trying to find pistons and rods the right size from not boring block
I can tell already you have no idea what is involved and your getting in over your head. If your sleeving the block then it should not be an issue to bore it at the machine shop. Have them get the pistons you need. Also 8:1 even 8.5:1 is to low espically for only trying to reach 400hp. Again you need to do years of research, then once you think you have it down search another year after that then repost. See you in 10years
hatchy
Aug 19, 2002 09:16 AM
