1FunRyd's 88-91 Prelude - Auto to 5 speed swap, B20A - H23 Non-VTEC swap
Old 01-20-2010, 10:05 AM
  #26
autoluder's Avatar
Default Re: 1FunRyd's 88-91 Prelude - Auto to 5 speed swap, B20A - H23 Non-VTEC swap
your 3g lude weighs about the same a 4th gen lude or 5th gen lude, ha, i was expecting it to be lighter.more like 2500lbs. so basically you have a 4g h23 si manual 160hp, you should get about a 15.2 out of it.. I ran a 15.7 in my auto si.
Old 01-20-2010, 10:06 PM
  #27
1funryd's Avatar
Are you sure about that, because the 3gp's are lighter than the 4th and 5th gens.
Old 01-21-2010, 05:10 AM
  #28
autoluder's Avatar
my fourth gen at the track scale with me in it with no passenger seat or spare tire weighed 2750, with 17s.
Old 01-21-2010, 06:37 AM
  #29
1funryd's Avatar
Yeah, mine was weighed in at the emissions scale. But the gross weight for a 3gp is 2650lbs, so mine is heavier due to what I am carrying in my back seat and trunk.
Old 01-21-2010, 09:34 PM
  #30
night_mare92's Avatar
wondering how where did u find the h23,i have a B20a but miles is over 300k mark and need a replacment if not an upgrade,i was thinkin the h22a buit price is also a factor.
Old 01-22-2010, 03:12 PM
  #31
1funryd's Avatar
I was fortunate and picked up the motor from an honest craigslist ad.
But you can to to www.tigerjapanese.com - an H22 longblock only is $693 + shipping
I sell the mounts for this swap for: $480 + shipping
The mounts will allow pretty much all the H/F series motors to drop in, there maybe some minor changes, like using a Prelude motor bracket in place of the bracket that came with the motor, but those are easy parts to obtain.
Just so we are clear, the kit comes complete with brackets, bolts, nuts and washers, and in a 3rd gen you must use the 4th gen rear engine bracket to bolt to the rear mount.
The motor bracket I am referring too is the little bracket that is bolted on the timing side of the motor, not the chassis bracket, I am not sure if the stock bracket of the F series motors are the same location, so its best to use the H22/23 bracket.
Contact me at: 1funryd@comcast.net - when ready.
Sean
Old 03-21-2010, 07:35 PM
  #32
1funryd's Avatar
Update: 3-21-2010:
I have finally completed the latest aftermarket for the 3GP community from AZ Race and Machine.
It is a Traction Bar system designed mainly for the H22/23 swappers but is also built for the B20a owners as well.
Here is a picture of the entire kit, all updated pictures have been posted at the front page.
Sean
Old 03-22-2010, 03:35 PM
  #33
BlackCatt's Avatar
Sweet traction bar. Looks very good quality.
Old 03-22-2010, 05:38 PM
  #34
Rockstar21's Avatar
for somebody who sells that many motors he should know the J32 is SOHC. lol
Old 03-22-2010, 07:02 PM
  #35
1funryd's Avatar
Oh it is...
Old 03-22-2010, 08:21 PM
  #36
Apex1972's Avatar
Oh it is...
whats that other piece in the back of the picture?
Old 03-22-2010, 10:01 PM
  #37
1funryd's Avatar
That my friend is the custom skid bar that protects the downpipe and oil pand and tranny from hitting first since its designed for the 88-91 Prelude H22/23 motor swap.
Due to the low hoodline on the 3rd gen ludes the H motors sit low in our chassis, so we needed to come up with a solution to protect our investments into the H motors swaps, and this is what AZ Race and I came up with.
Intially we all wanted a skid plate, but the motor is too big with not enough room for the Radius rods to get full articulation during hard turning or over bumpy roads.
Go to the front page and you will see it installed. I update all my pictures up there.
Edit: All hell I will just post it up here.
Sean
Old 03-23-2010, 06:31 PM
  #38
kilerintegra's Avatar
like your swap. I have an 89 prelude and i would like to swap it, everything you did really helps me accept mine is an S model which means its carb any suggestions? Also what wiring harness did you use since your motor is an obd1 or obd2 and the car is an obd0? Oh and you sell the mount kit but do you sell that traction bar kit also?
Old 03-23-2010, 07:58 PM
  #39
1funryd's Avatar
I do sell the mounts. So email me at my email in my sig below.
Update: 9-30-2016 -
I have moved to WireWorx and sell the H22/B-Series conversion harness made specifically for the 88-91 Preludes
Note: Rywire does not support this swap, they will just sell you a general harness let you figure it all out, so please do not go to them for support, come to me and I will get you a better and more affordable conversion harness from Wireworx.
Also all orders for this harness has to come through me, that is the arrangement I worked with WireWorx
Email me for details: 1funryd@comcast.net
You will need to pull the entire harness of a 90-91 lude from engine to interior for this swap.
Here is the link to a member of pp.com who did the swap from S to Si to H22: http://www.************.com/forums/s...d.php?t=271916
Here is his swap.
Old 04-13-2010, 10:24 AM
  #40
do you happen to have a link for the axles you have? i have search everywhere for them and all I can come up with is for EF civics and crx. any info would be great
Old 04-28-2010, 10:57 PM
  #41
upsalon89's Avatar
Hi there im new to the site and cant seem to figure it out but im looking for someone who is familiar with Honda Preludes i actually just bought mine about 2 weeks ago have friends who work on them but cant answer my question maybe you can. So if i am driving and hit a bump or make a sharp turn this insanely annoying beeping noise comes on and doesnt shut off untill i shut my vehicle off and under my rpm guage theres a person in a seatbelt that icon starts flashing also above my speedometer it says door/then shows someone in a seatbelt that also flashes. when i pull on my door panel its kinda messed up but when i pull the door panel about a half a foot towards me it shuts off then if i let go hear like a click and it turns on. so my question is how would i fix this issue?
Old 04-29-2010, 01:48 AM
  #42
1funryd's Avatar
www.raxles.com talk to Marty and tell him Sean 1funryd sent you.
There is a recall on the belt buckles for this generation of Prelude. The beep is coming from your sensor probably being damaged in the belt buckle, if you look up at your belt indicators in the middle of your ceiling right in front of the sunroof visor there is a light with the a icon of a man with a belt across him, if that is on, that is telling you that your sensor is gone bad.
Come over www.p r e l u d e p o w e r.com(no spaces) and we have a wealth of information regarding this chassis plus the online PDF manual as well.
Old 04-03-2011, 05:57 PM
  #43
1funryd's Avatar
Update:
On Feb 1st 2011 @ 10:20am in the morning while heading to a customer on the job, I got into a pretty bad wreck.
I was taken to the hospital in an ambulance and my car was totalled.
Here is the result of that wreck:
Needless to say that I was devastated and pretty much down on top of being hurt and out of work for about a week.
So, I pondered on whether or not to just total it all and call it quits. So proceeded to pick another 88 prelude automatic for daily driving purposes only, as I already know these cars fairly well.
I was going to let it go to the scrap custom parts and all, but I just could not let enough alone, so I scoured Craigslist and found a perfect shell to transfer all parts.
Only a month after the accident I started my journey back.
Here was the shell I picked up:
As you can see I started pulling the B20a5 motor out right away:
Then I pulled the H23a out of the crunched up yellow lude, as we cut the front end off to pull the motor I was holding back the tears.
It took me almost 9 years to get to this point, and it was all taken away in a matter of minutes
So everyweekend since I got the shell I worked on her with my friends HUY and Justin, and we got everything moved over: Engine, tranny, exhaust, suspension even the Upper control arms and hubs and wheels, chairs and miscellanous parts like AC lines and some harnesses that I just cut.
Also my custom powersteering reroute-line.
Man what a process!!! But all of us swappers never quit do we???!!!!!
We had a harder time swapping to this chassis because the 90-91 chassis is slightly different for some reason, you have to start with the Transmission first then loosen the rear engine bracket and keep the rear mount off until you have the transmission side in the bracket first then work the rear mount next.
It takes some wiggling and finagaling but it will work and everything will bolt up.
Here are the completed swap pics:
Traction bar in...
Here are the body shots:
And now she is up and running, I just need to her to get past emssions. I failed on Friday when I was trying to get the title transferred over.
So minor setback, she is done and needs a cleaning obviously and also got to get the stereo and car alarm up as well.
Enjoy folks!!!!
1FunRyd II is now officially up and running.
Old 04-04-2011, 12:54 AM
  #44
BlackCatt's Avatar
Really feel for you man, losing your old lude. Great to see
you just got back up and started again on your new one.
GL getting it all set up as you like.
Old 04-04-2011, 06:51 AM
  #45
Hawkze_2.3's Avatar
AAAHHHHHHH! so sorry to here about your yellow car. Good luck with the new one, I am sure it will be better than the first
Old 04-04-2011, 06:56 PM
  #46
1funryd's Avatar
Thanks guys.
Yes it was a low blow, and I was very close to just walking away and never coming back, but 9 long years of saving up and hard work, I just could not do it.
Next year I will put the H23vtec motor in, so that is the game plan for the upcoming year.
I spent more than my budget, to just recover the parts and swap them into another chassis.
Old 07-04-2013, 03:45 AM
  #47
1funryd's Avatar
Here is what I have been up too in the past two years since the accident.
I have become the only person(small business) to make the only bolt up lips for the 88-91 Preludes.
Completed and for sale - Front Lip for 90-91(still working on 88-89 lip) Prelude:
Installed on a 90-91 INX Prelude
90-91 Prelude:
90-91 Prelude:
Side skirt OEM version replica - for 88-91 Prelude(in progress still):
Completed and for sale - Rear Lip - for 88-91 Prelude:
Finished product on a 90-91 Prelude:
For details on these lips, contact me at: 1funryd@comcast.net
Old 08-06-2013, 11:30 AM
  #48
preludeSI88's Avatar
im pretty new to this sight would anyone recommend a jdm B20 for the 88 honda prelude si? if not what motor should i swap into it? any input would be a huge help thanks guys
Old 08-06-2013, 03:24 PM
  #49
1funryd's Avatar
Make sure that you understand that the only B20 motors that will directly swap in will be the Prelude 88-91 B20a5, B21a1, B20a(not to be confused with the CRV B20b).
And the motors look like this:
Old 08-06-2013, 03:54 PM
  #50
h22god's Avatar
Awesome job man! Keep it up!!!
Quick Reply: 1FunRyd's 88-91 Prelude - Auto to 5 speed swap, B20A - H23 Non-VTEC swap
