seafoam, CB700sc
i ♥ snails
seafoam, CB700sc
Hey guys ill start out with some basic info, i ride an 1986 Cb700sc nighthawk, i just changed the oil like two weeks ago, when i changed the oil i added seafoam to a full take of gas and also added like 4 ounces to the crankcase oil. I have read you need to change the oil after adding seafoam to the oil because it thins out the oil ruinings its viscosity properties and also can uncork alot of small debris that can lead to bad things. the oil only has about 200+ miles on it with the seafoam, should i go out and change the oil as soon as possible or is it ok to leave it the way it is. The oil was just regular castrol 20w-50 oil. Let me know what you guys think! also is castrol actevo 4 stroke oil any good? i think im going to use it next oil change. Thanks!
