Monster s2r front end interchangability?
Anyone know if the superbike (748/9xx or xx9 series) front ends fit (forks, triples, etx)? I just bought an 06 monster s2r. Thanks.
Re: (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy »</TD></TR><TR><TD CLASS="quote">Pics of new bike?</TD></TR></TABLE>
Re: (Ross)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross »</TD></TR><TR><TD CLASS="quote">What the hell is wrong with you?</TD></TR></TABLE>
I have problems passing up really good deals; I guess I am a consumer *****.
Re: (.Ash)
If it is like the previous gen Monster then "yes" you should be able to switch over the forks, calipers and such. However, the IIRC, the monster forks and top triple have a different diameter (smaller than the SBK up top, bigger below), so you'll you need either:
A). Machine your stock top triple and shim the lower or
B). Buy a Cyclecat triple, install that and use the shim kit provided (this is what I did, when I put 998 forks and clipons on my SS)
However, you're now going to need to mount the clipons beneath the triple and you're either going to have to use SBK clipons (to fit the SBK forks) or buy aftermarket clipons (Cyclecat, Woodcraft, whatever) of the appropriate size.
After all that, don't forget to set the sad, preload and all that other good ****.
Congrats! Does this mean you sold the 748?
Oracle of GDD
1 Post
Re: (bb6h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a »</TD></TR><TR><TD CLASS="quote">Congrats! Does this mean you sold the 748?</TD></TR></TABLE>
What do you think?
Ash is a baller! He only sells bikes when he is sick of looking @ them.
What do you think?
Re: (bb6h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a »</TD></TR><TR><TD CLASS="quote">If it is like the previous gen Monster then "yes" you should be able to switch over the forks, calipers and such. However, the IIRC, the monster forks and top triple have a different diameter (smaller than the SBK up top, bigger below), so you'll you need either:
I will have to get out the micros and start measuring. I kept the 748; I have a very hard time parting with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu »</TD></TR><TR><TD CLASS="quote">if the ID is the same, then yes... if not those forks are only a triple clamp away </TD></TR></TABLE>
I will probably use the 748 for reference + mesaurements.
