Maintenance
Old Apr 26, 2004 | 04:57 PM
Kris's turbo's Avatar
Default Maintenance
Hey I'm new to bikes, only had my gsxr for 6 months. Its a 99 gsxr 600 with 20,000 miles, what do you think I need to do? I have already changed the chain and sprocket, and I am about to put new seals in the front forks. Thanks for your help.
Kris
Old Apr 26, 2004 | 05:33 PM
ScubaStevo80's Avatar
Default Re: Maintenance (Kris's turbo)
Do all the regular checks (also check the manual)... check the tires, bolts, fluids, oil, cable assemblies for wear, maybe run a compression test if possible and check the clutch.
Old Apr 26, 2004 | 06:38 PM
rapid_roy's Avatar
I am sure you need to do a valve adjustment. Also check your head bearings, fork seals and change your fork oil. Get a can of Seafoam and follow the directions on the can.
Old Apr 26, 2004 | 08:52 PM
Kris
d2r
Oct 30, 2008 10:25 PM
leroyb
Aug 30, 2007 02:42 PM
itr817
Aug 3, 2003 12:48 PM
from_zer0
May 11, 2003 12:49 PM
jokerstud
Dec 22, 2002 08:27 PM
