help installing a slip on!
Old May 12, 2007 | 12:24 PM
.Kevin.'s Avatar
Default help installing a slip on!
Alright I bought a vanes and hines slip on off of ebay used and I seem to be having a problem.
The bike is a yamaha yzf600r
I went to put it on and the part that slips over is well to large. I tried using a reducer from the retards at napa and that failed. Is there supposed to be a gasket that connects the mid pipe to the header? How could I customize it to make it fit?
Please help!
Old May 12, 2007 | 12:54 PM
Willybeen's Avatar
take it to a reputable welding shop and see if they can weld a flange onto it? if not.. buy the correct fitting pipe
Old May 12, 2007 | 01:02 PM
rdblckSV650S's Avatar
Default Re: (Willybeen)
sounds like you ended up with the wrong pipe.
You'll have to come up with some way to fab it on there.
Old May 12, 2007 | 01:13 PM
Gizmo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willybeen &raquo;</TD></TR><TR><TD CLASS="quote">take it to a reputable welding shop and see if they can weld a flange onto it? </TD></TR></TABLE>
that should do it.
Old May 12, 2007 | 03:25 PM
.Kevin.'s Avatar
Default Re: (Gizmo)
the jerk said it was taken off of a 96 yzf600 and I know ALL yzf600 parts are interchangable, well it was off of a 96 fyz600.... Im pissed
Old May 12, 2007 | 05:07 PM
hi mom's Avatar
Default Re: (Ep_Kevin)
Okay, maybe I'm confused. But a slip-on is not suppsoe to be tight fitting. Hence the name '' slip-on''. The pipe is suppose to slide over the mid-pipe and then with a hanger attach to the bike. Unless you mean a full exhaust system, minus the header. Then yesy ou got the wrong pipe...
Old May 12, 2007 | 08:21 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: (hi mom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hi mom &raquo;</TD></TR><TR><TD CLASS="quote">Okay, maybe I'm confused. But a slip-on is not suppsoe to be tight fitting. Hence the name '' slip-on''. The pipe is suppose to slide over the mid-pipe and then with a hanger attach to the bike. Unless you mean a full exhaust system, minus the header. Then yesy ou got the wrong pipe...
haha "slip on" doesn't mean it doesn't fit the pipe, there isn't supposed to be play especially after you clamp it.
I would weld it, or have someone do it for you if you don't know how
GeeGee
Welding / Fabrication
May 11, 2007 06:35 PM
danielm3
12
Mar 2, 2006 06:24 PM
u2civic1
Aug 30, 2005 09:47 PM
TurboJesse
18
Dec 1, 2004 10:23 AM
RACEPAK
16
Aug 19, 2004 04:36 PM
