digital conversion
Old May 6, 2002 | 06:01 AM
crxwanted's Avatar
Default digital conversion
Does anyone know if it is possible to convert a non-digital bike to digital i.e. speedo/odometer? I'm thinking this would require an ECU and I'm unaware if older model bikes w/out fuel injection even have ECUs. I wouldn't see why they would but I don't know for sure. Any input?
Old May 6, 2002 | 07:03 AM
The_Head's Avatar
Default Re: digital conversion (crxwanted)
You know what they say, anythings possible if you have enough money. I dont think it would be worth the trouble. my $.02
>>John
2000 GSF1200S
Stage 2 jet kit
Vance & Hines Full Exhaust
JE 11:1 Pistons
etc, etc.
Old May 6, 2002 | 09:48 AM
Raz1983's Avatar
I think all you have to do is earth it, and it gets the pulse from... dunno. heh i dont even know what im talkin about right now, but I remember putting a digital tachometer on my small KSR just by placing one of the lines on the frame.
Old May 6, 2002 | 12:11 PM
meept's Avatar
Theoretically, this could be done, if all the sensors the digital dash reads output the same values as the non-digital ones (or if the digital sensors will fit). On Hondas anyhow, the tach is read from the ECU, and all the others are various sensors which for the most part use the same resistance values etc. The hard part of this sort of conversion is getting the digital dash in the first place - they're not cheap at all. It will be a lot of work and fiddling around though...you'd have the wiring diagrams for yours and the donor bike memorised by the time you got done with it.
I had planned on doing this to one of my bikes as I'd modified it so the OEM instrument panel wouldn't fit, but I found a way to retain the OEM panel and the digital-dash plan went by the wayside.
Old May 6, 2002 | 06:46 PM
redblues's Avatar
New User
http://www.touratech.com
Look at the IMO motorcycle computers.
I have one on my dual sport (DR350), it works very well.
Old May 8, 2002 | 10:15 AM
Luke's Avatar
Default Re: digital conversion (redblues)
Be carefull what you use. A mate of mine has an SP1 display and its a right pain to configure.
Old May 8, 2002 | 04:00 PM
meept's Avatar
Default Re: digital conversion (luke)
I was actually going to use the SP1 (RC-51 here) display on my bike. Everything would've worked as all the sensor values are the same, but I am not 100% sure the tach pulses would be correct, as the display expects a v-twin and I was putting it on a V-4.
boostdeliquent
Engine Management and Tuning
Dec 8, 2012 05:05 AM
Snailor Built
Dec 19, 2011 11:50 PM
jonathan13
Honda Motorcycles
21
Jun 10, 2009 12:07 PM
85
Honda Motorcycles
16
Jan 19, 2006 09:20 AM
99blkx
Honda Motorcycles
20
Sep 7, 2004 12:44 PM
