Broke off a peice of metal on the inside of the crankcase? picture included!
Re: Broke off a peice of metal on the inside of the crankcase? picture included!
will this effect my oil pressure and ruin the engine or route the oil to the wrong place??
Did you lose the piece that goes there? Sometimes you can braze it back. I don't know how that'll effect the oil. What does the outside cover look? Is it part of oil channel or is it closed.
Just curious, how that happened.
i still have the peice and what do you mean braze it? its closed in that surface to the case so im pretty sure i ill have to tac it in place or who knows what would happen to the engine
-Intl Steve Krew
If you tear that crankcase apart that piece can be welded back on just fine.
ill clean it good and cover up the gears from splatter with rags and get a shop to weld it to lazy to remove everything
